Sponsored by: Real Truck
Load Range C tires
Old Dec 23, 2007 | 12:23 AM
ghunt's Avatar
ghunt
Load Range C tires
I just found out today my truck has Load Range C tires on it. 2714 lbs per tire I think it was.
Would it be OK with these or should I be looking at new tires?
Old Dec 23, 2007 | 01:24 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I wouldn't go any lower then D load on my Truck but thats just me
Old Dec 23, 2007 | 01:40 AM
ghunt's Avatar
ghunt
Yeah, I know...
I was thinking about getting some new tires anyway, I guess this gives me a good reason to.
Old Dec 23, 2007 | 06:12 AM
UP_There's Avatar
UP_There
load range C isn't a great idea on our trucks......go with at least a D range, E if you tow often. If you don't tow, there are plenty of good D range tires that will do the job just fine, I have D range on mine, and tow a few times a year, but nothing more then 7000lbs, no problems here.
Old Dec 23, 2007 | 06:46 AM
svt2205's Avatar
svt2205
You guys should note that he's refering to an earlier F250. Weight ratings have gone up significantly since those days.
On wikipedia, I found this.
F-250: 3/4 ton (6,600 GVWR max)
F-250 HD: 1994-1997 Heavy Duty 3/4 ton (9,000 GVWR max)
If this info is accurate, he's got nothing to worry about. Check the sticker on your truck to verify your GVWR is in this range.
Old Dec 23, 2007 | 07:01 AM
ken kenmnedy's Avatar
ken kenmnedy
yea but he wants new tires and needs a better load range we all tend to carry the load now and then like they say better to have it and not need it than to need it and not have it
Old Dec 23, 2007 | 07:49 AM
redford's Avatar
redford
FTE Leadership Emeritus
Load range C would be OK on a 1994 F-250 unless you are towing.
Old Dec 23, 2007 | 08:24 AM
Dwinkie's Avatar
Dwinkie
the larger the load letter the heavier the sidewalls are and the greater resistance to sway just like lower profile i found on 03 that fully loaded bed or truck camper load d geolander were quite marginal
Old Dec 23, 2007 | 09:17 AM
BillyBob69's Avatar
BillyBob69
LIke pretty much said before......If you are not going to tow or haul....you are OK...If you are gonna haul or tow...minimum rating D better with E for heavy loads.
Old Dec 23, 2007 | 09:26 AM
cdrmotorsports's Avatar
cdrmotorsports
I agree. Load range D would be the minimum, but for the extra money load range E is the way to go. I've got load range Ds on my Dakota. I wouldn't want to go with Cs on a larger truck.
Old Dec 23, 2007 | 11:06 AM
ghunt's Avatar
ghunt
GVWR on my truck is 8600 lbs, although I don't know what the truck itself weighs.
The stock tires were 235/85R16 E-rated tires
BTW the rear GAWR is 6084 lb.
Old Dec 23, 2007 | 11:17 AM
blue350's Avatar
blue350
Was this a used truck you bought and it came with C's. If it is a F-250 I belive law requires a minimum D load range. May be diffrent in your state though. Like everyone else has said you can get away with C if you dont tow but I would go with a D range IMO.
Old Dec 23, 2007 | 01:18 PM
ghunt's Avatar
ghunt
Yes I bought it used.
Old Dec 23, 2007 | 02:13 PM
cdrmotorsports
Go for atleast the Ds. You will feel much safer.
Old Dec 23, 2007 | 05:14 PM
UP_There's Avatar
UP_There
my theory is.......why let a blowout endanger your life or your family's life, and change your mind later about D or E range. I'd get the C's off your truck pronto if I was you! Safety should be the major concern
