302 heads
Old Dec 24, 2007 | 09:57 PM
95F350XL's Avatar
95F350XL
Anytime, Were here 2 help. Good luck with it, if you have anymore questions just ask. Have a Merry Christmas.
Old Dec 24, 2007 | 10:09 PM
Ervie's Avatar
Ervie
So the Ignition mod you say is on the dr fender and it is a 1 wire plug, is a good thing you told me this because where the coil mounts to the engine was another bracket that had a 1 wire connection i thought that was it
Old Dec 24, 2007 | 10:14 PM
95F350XL's Avatar
95F350XL
There will the be the mod on the fender and there will be a little connector in the wiring harness. Im trying 2 find the pic. Here is the link 2 it. https://www.ford-trucks.com/forums/6...94-1994-a.html
Old Dec 27, 2007 | 10:54 AM
Ervie's Avatar
Ervie
Ok im not sure whats going on exactly but everyones telling me to line up m marks at 10 degr before TDC but the only way it will start is 0 deg. So do i just advance it on my own then plug my shortning bar back in.
Any way got everything back together and was leaking from the thermostat housing, see what happend i went to get a new one and the idiots sold me the wrong one.
so i put the old one back in, and the thermostat must of came out of that groove and was leaking coolent faster then i could put it in.
Old Dec 27, 2007 | 06:13 PM
Ervie's Avatar
Ervie
well finally done, purrrrrrrssssss like a kitten. so far no leaks or nothing. just want to say thanks for the advice boys.
Till next time
Erwin
Old Dec 27, 2007 | 07:40 PM
flareside_thunder's Avatar
flareside_thunder
Glad to hear it and glad we could help.....Later On
JR
Old Dec 27, 2007 | 08:48 PM
Dean88's Avatar
Dean88
I broke 2 bolts off when I rebuilt my motor.
It took a good solid week of drillin, soaking, and easy outing.
It wouldn't have been so bad, except Dad and I weren't thinking on the first one we tried drillin and used a Titanium bit and the tip broke off in the bolt, and that took hours of drillin and 12 standard drill bits to finally drill out that bolt.
Old Dec 27, 2007 | 08:55 PM
flareside_thunder
I hear ya...I soaked the ones on my truck fer almost a week then I broke an easyout off in one....that's when I decided to go talk a buddy of mine outta the heads on his spare lightnin motor......broke a bolt off in one of them too....I took it to a machine shop...the guy drilled it torched it and plasma cuttered it and still couldn't get it...took him over 6 hours of getting frustrated and trading it off to other people before it finally got drilled out.....well worth the 50 bucks......
JR
Old Dec 27, 2007 | 09:47 PM
Ervie's Avatar
Ervie
I dont know what ford was thinking using such small intake bolts anyhow.
Old Dec 28, 2007 | 06:08 PM
flareside_thunder
I wanna know what they are made of if the machien shop couldn't do the above....
JR
Old Dec 28, 2007 | 06:18 PM
95F350XL's Avatar
95F350XL
Prob some space age junk, that is strong but can rust where the stud and nut can rust into 1 peice like my old exhaust manifold bolts. I just used stainless steel and a healthy dose of anti-seize.
shephard199
Jan 14, 2010 09:20 PM
bigcountry1009
Jan 11, 2009 12:02 PM
alwaysmessedup
Jul 14, 2005 10:00 AM
swall
Jun 26, 2003 06:23 PM
TorqueKing
Feb 22, 2002 12:16 AM
