I bought an 1989 4WD F350 Dually with a dump bed, 7.3 diesel engine. After I hauled the first load, I saw fluid leaking under the right rear wheels, so I figured 2 new brake cyls would do it. Well to make a long story short, I had to pull the hub and install a new axle seal, and I replaced the pinion seal as well. Now I have 3 questions for the experts-
1) This rear end is the Sterling 10.25 full floating axle. I repacked both the inner and outer wheel bearing according to the Chilton manual- Now I read on this forum that you should not pack the bearing, it restricts oil flow to the outer bearing. Any thoughts?
2) One guy here suggested using the Lucas oil, as it really adheres to the bearings. Any advantage of Lucas oil over synthetic?
3) I'm embarrassed to admit it, but I can't find the filler plug on this differential. Anybody know where the hell it is?
Thanks all...Merry x-mas
I always hand pack the bearings on a full floater.
No need to over do it though, just enough grease to ensure sufficient lubrication until the rear end grease gets to them so they do not run dry at first.
OK. First on a 10 1/4 rear diff you DO NOT pack the rear wheel bearings in the hubs. You lube them with differential oil and put then in.Just before you put in the outer bearing into the hub,you squirt some lube into the rear hub and then put the bearing in and torque the hub nut.Then put the axle in and torque the axle nuts.
Second you fill from the front of the diff.You may have to dig arround for the plug because of mud build-up
Shat, one guy says pack them, another guy says don't pack them, which one is it? I gues i need to talk to somebody who rebuilds these things for a living. What about this Lucas oil? anybody use it? I hear it's a good oil or should I take it back for synthetic?
It will work either way, hand pack a little grease on them, no need to over do it as it is just to lube them until the gear lube gets to them filling the hubs. Or squirt some gear lube into the hub just before you slide the axle in the last little bit and bolt it in place.
Just don’t install the bearings dry.
Fill the differential up the to the fill plug and squirt a bunch of extra in, then take it for a ride turning corners so it runs out to the hubs.
Then check the level again and top it off so it is full to the bottom of the fill plug.
