speedo issues
Old Dec 21, 2007 | 11:43 PM
gh1334's Avatar
gh1334
speedo issues
1985 f-250 just bought last week. rebuilt motor turbo-ed new tranny as in my last thread.
Speedo quit. small parts to replace or go whole cable assembly?
Old Dec 21, 2007 | 11:52 PM
fellro86's Avatar
fellro86
Need to check to be sure that the cable turns, both at the speedo end and transmission end. It can be a bit of a pain, but you need to likely take the cluster out. First though, do you have cruise control? If so, the speed sensor may have seized up, so you need to take it loose to check that. I have seen cables break, the plastic gear strip out internally, as well as the teeth, and then sometimes, but more rarely, the speedo head fails. generally it will be either the cable, speed sensor, or gears in the trans. You have one that goes around the tail shaft, and one that is driven by that gear.
Old Dec 22, 2007 | 12:33 AM
gh1334's Avatar
gh1334
i have cruise control but it does not work. trans is brand new. less than 300 miles. will check cable at both ends. thanks
Old Dec 22, 2007 | 01:37 AM
fonefiddy's Avatar
fonefiddy
As fellro stated, "CHECK THE SPEED SENSOR"
If you buy a new cable, and the senor is binding, it'll tear the plastic end off your brand new cable.
Old Dec 24, 2007 | 06:50 PM
ford trans tech's Avatar
ford trans tech
if it is automatic the gear in the trans is steel most likely the plastic gear has stripped on teh speed sensor if it has lube teh cable before reinstalling it
colemand
Modular V8 (4.6L, 5.4L)
Dec 5, 2002 05:34 PM
adelyser
1978 - 1996 Big Bronco
Oct 10, 2002 01:48 PM
msalvetti
Jan 19, 2002 12:51 PM
73Custom
Jun 6, 2001 08:16 PM
PAUL_2
Oct 29, 2000 11:30 PM
