Sponsored by: Real Truck
46 - 48 MPH bounce
Old Dec 21, 2007 | 09:23 PM
banditsdaddy's Avatar
banditsdaddy
Question 46 - 48 MPH bounce
I have a 2006 F350 SRW 4X4 SC LB with 18" Alum. wheels that has a bouncing feel at 46 - 48 MPH like a wheel is out of balance. Had the wheels balanced 3 times and the bounce is still there and only at that speed. Has anyone else had this problem with their truck and found the problem? Any suggestions would be appreciated.
Old Dec 25, 2007 | 08:42 PM
maadman's Avatar
maadman
Find a tire shop that is capable of doing an on-vehicle balance. This will help determine which corner/s are causing the bounce and then steer you in the right direction for a cause, such as ball joints, wheel bearings etc. Also, even thou you have had the tires balanced numerous times, check the weights used. If you have an excessive amount of weight on one tire (this can cause a low speed bounce) have them break the beads and spin the tire 180 degrees on the rim and rebalance it. Chances are good the weights needed will be less and your bounce will disappear. Good luck.
Old Dec 25, 2007 | 09:42 PM
UGA33's Avatar
UGA33
Mine does this also. There is a tsb for it:
TSB
07-5-11 VIBRATION/HOP AT 40-48 MPH (68-77 KM/H) - (8.0 HZ) - TRAILER HITCH EQUIPPED VEHICLES ONLY
Publication Date: March 1, 2007
FORD: 2005-2007 F-Super Duty
ISSUE:
Some 2005-2007 F-Super Duty vehicles with a long wheelbase of 156", 158", or 172" (396, 401, or 437 cm) and equipped with a trailer hitch may exhibit a vehicle vertical vibration, often described as "hopping", on smooth or coarse road surfaces in the 42-48 MPH (68-77 Km/h) speed range. Although this behavior is considered normal for an over 8500 GVW truck, some customers may be sensitive to the concern.
ACTION:
To improve the 42-48 MPH (68-77 Km/h) vertical vibration, follow the instruction sheet included in the Damper Service Kit.
NOTE: THE INSTALLATION OF THIS DAMPER WILL NOT IMPROVE RIDE ON SEGMENTED CONCRETE HIGHWAYS, STEERING WHEEL VIBRATION/SHIMMY, OR GENERAL HARSH RIDE CONCERNS.
PART NUMBER PART NAME
5C3Z-5D008-A Damper Service Kit
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
070511A 2005-2007 F-Super Duty With Trailer Hitch: Install The Damper Service Kit. 0.6 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
5D008 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
__________________
Old Dec 26, 2007 | 05:25 AM
JOE-M's Avatar
JOE-M
Try rotating the tires front to back. Make sure you tighten them back up evenly and torque the nuts to spec. Sometimes it helps, sometimes it doesn't.
Joe
gdiehl
6.7L Power Stroke Diesel
15
Sep 7, 2017 10:13 PM
02TB250
Jul 31, 2017 05:54 PM
dmgiff
Jul 27, 2007 08:43 PM
buckeyebronco
1978 - 1996 Big Bronco
May 26, 2006 11:14 AM
Nod
Mar 21, 2002 09:23 PM
