Rear end bounce at 45 and 65
I have a 2013 f350 4 door longbed single rear wheel. The rear end bounces violently at 45 and 65 mph. Just today I had the truck had new shocks put on, was aligned balanced and tires rotated but it still bounces. I know there was already a thread on this but i never saw if the guy found a solution. If someone could post the link of the thread or chime in if they ever found a solution it'd be appreciated
https://www.ford-trucks.com/forums/1...40-45-mph.html
Not a 6.7L issue and has been around for years. good luck.
Yup, work that 1 ton with a 10,000 pound trailer and your problem will be solved.
It is a combo of a 1-ton stiff suspension along with concrete highway with expansion joints at certain speeds.
I found that it is the best time to phone my kids, via hands-free, so they can listen to the vibrato in my voice.
Wheel Length base and bouncing along concrete highway expansion sections is a different problem than the ~40 mph rear bounce on any road surface.
Check -> Rear end bounces @ 40-45 MPH
BOUNCE
Hello,
I have the TSB part although I never installed mine on my 2016
I do ride the truck around with only 65 PSI tire pressure when not towing my trailer.
Otherwise at 80 psi it rides like a rock unloaded and hops to the side on rough roads.
great ride at 65 up front and 60 to 65 in rear empty.
John
John
Hello,
John
John
How about the Sulastic shackles? They should take some rigidity out of the rear.
https://www.ford-trucks.com/forums/1...2-ton-now.html
Received 6,619 Likes
on
