Need Help troubleshooting codes
Old Dec 21, 2007 | 09:17 PM
start2finish's Avatar
start2finish
Exclamation Need Help troubleshooting codes
Okay, 1999 F-350 DRW 4x4 Crew Cab, automatic transmission. xlt trim
206,000 miles. have owned the truck a couple of years, bought at 140K or so.
Had an intermittent problem with a SES light flickering and reduced power, terrible mileage. this was off and on for 20K miles. a whole lot more good than bad which made me give up on fixing because I could not dupliate to diagnose.
now SES all the time. less response, steady 35-45 MPH driving produces a miss and vibration. WOT less power but no vibration.
codes
P 0470- (already replaced the Exhaust Backpressure sensor, also replaced the tube because I broke after an hour or 2 of trying to clean out. ) this may have helped a little, but didn't fix
P1316 Ignition diagnostics monitor fault . ???
it also had
P 1105 and P1106 stored but did not return after clearing. the other two popped back immediately.
the codes haven't been reread since dealing with the P0470
I also removed the battery cables for a couple of hours after replacing the sensor. I don't know if that will clear the PCM on this truck or not.
valve cover gaskets?? HELP
Old Dec 21, 2007 | 10:36 PM
bdrummonds's Avatar
bdrummonds
First what are you using to scan the codes? Next refer to this page for your code explanations http://guzzle.rbmicro.com/dtc.html
Click on the range of codes at the bottom to get a definition
1316= injector circuit/IDM codes detected
1105 and 1106 are for a dual alternator truck, is yours a dual alternator?
It sounds like you may have a UVC harness coming loose, or a bad injector, or worse your IDM may be about to let go.
IDM= Injector Driver Module
Old Dec 22, 2007 | 11:28 PM
start2finish
the codes were scanned by an independant garage. can't remember the name of the scanner.
also the truck does not have dual alternators.
the garage that scanned told me to pull the valve covers and look at the wires.
Old Dec 23, 2007 | 10:45 AM
start2finish
any ideas on what to check and how.
Old Dec 23, 2007 | 11:01 AM
medhvac's Avatar
medhvac
u need to check this connecter under the valve covers not to hard to do!
<a href="http://s265.photobucket.com/albums/ii239/medhvac/?action=view&current=driverside2.jpg" target="_blank"><img src="http://i265.photobucket.com/albums/ii239/medhvac/driverside2.jpg" border="0" alt="Photobucket"></a>
Old Dec 23, 2007 | 01:42 PM
clintbonnie's Avatar
clintbonnie
I completely agree.. you need to pull both valves covers (gaskets are reuseable) and you probably will find the 9 pin plastic connector is loose.. (mine was about 1/4" loose).. At the same time inspect all the wiring harness for rubbing and shorts. To fixed the connectors, i just made a home made shim to slip behind the plastic locking tabs. This will stop the connector from coming apart.. see my gallery for pic of my shim.... Or.. you can buy a plastic clip from Ford which does the same thing..
Using the shim method, the cost of repair = $0.
Old Dec 25, 2007 | 06:55 PM
start2finish
i was reading somewhere the ohm readings (proper) for the gp relay and the injector wiring in the outside of the plug. I cannot locate it after a search in this forum. whould anyone know this. it had the labeling of the plug along with a ohm reading so I could test without pulling the covers. (hopefully)
Old Dec 25, 2007 | 08:13 PM
lhud's Avatar
lhud
Hey Medhvac,
Nice pic of that UVC harness!
I recently had that same P1316 code and my injector buzz test results were fine. So, I pulled the driver's side VC (easiest to start with) and sure 'nuff, the harness had separated approx. 1/4" or more causing a very loose connection. My harness also did not have those plastic clips to hold the two halves together. You can push the two halves together and that's fine for now, but down the road will eventually separate again.
I do not see the plastic clip on your pic Medhavc - did you put that in after the pic?
My pics did not turn out as good as yours.
Therefore, suggest someone do that injector buzz test and if the code P1316 is still there, then the UVC is likely the culprit.
The plastic clips come three to a pack, one for each side and one spare. Just be sure to protect the oil drain holes with rags, paper towels or whatever.
And as Clintbonnie mentioned, do check to make sure the electrical wires in there are not against the push rod or any other moving parts.
Good luck,
Old Dec 25, 2007 | 09:12 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Sorry for the delay. Worked today and it was Christmas. Here ya go, good luck.
To check the harness ohm it at the Valve cover connector on the outside.
Pin Out
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
***The injectors fire with a 115VDC signal from the IDM do not pierce to wires to test.***
Ohm between "I" and "C" to test the injectors, should be less than 5.0 Ohms
To check glow plugs Ohm between "G" and battery ground should be between 0.1 and 2.0 Ohms
Old Dec 26, 2007 | 12:56 PM
start2finish
Originally Posted by lhud
Hey Medhvac,
Good luck,
oil drain holes? sounds like trouble, please explain.
Old Dec 26, 2007 | 02:56 PM
clintbonnie
Hey Medhvac,
Good luck,
Plug the drain holes?
Old Dec 26, 2007 | 05:00 PM
lhud's Avatar
lhud
Start2Finish,
The oil drain holes are located on the perimeter edge of the head on the lower side.
This allows the oil that lubes the valve springs, push rods, etc. to drain and be recycled.
If you use the plastic retainers they can be lost down into those drain holes and maybe cause some sleepness nights for fear of damaging the engine.
Later,
Old Dec 26, 2007 | 10:21 PM
clintbonnie
Oh..OK... I used home made shims behind the locking tabs. they won't come out .
Meydawg51
22
Aug 30, 2016 03:59 PM
jyblood
Jul 24, 2015 02:41 PM
Riversonly
Mar 1, 2015 05:25 PM
2006powerstroke90
Sep 9, 2014 07:39 PM
griffins45619
Nov 29, 2010 02:38 PM
