96 F-150 I6 Stalling
Old Dec 23, 2000 | 07:03 AM
chunk's Avatar
chunk
My f-150 i6 stalls when braking to a stop. the truck will idle rough then die. when it takes a few seconds to restart, when it does restart grayish smokes emerges from the exhaust pipe. it happens no matter whick tank i use and only after coming to a stop. it does not matter if the air cond. is on. if anybody can help me I would be very grateful.
Old Dec 23, 2000 | 01:17 PM
PAUL_2's Avatar
PAUL_2
It kinda sounds like you have a vacuum leak ? If you idle the engine & depress the brake pedal does the rpm change ? What kind of maintenance sched has the truck had ? Any other driveability troubles ? Is it a manual or auto trans ?
Old Dec 23, 2000 | 04:17 PM
chunk's Avatar
chunk
[font size="1" color="#FF0000"]LAST EDITED ON 23-Dec-00 AT 05:19 PM (EST)[/font][p]thanks for the reply. the rpm does not change when the brake pedal is depressed. manual trans \no other problems. i shall check the vacuum lines. the maintenance record is excellent. 41,000 mi, no breakdowns.
Old Dec 23, 2000 | 06:50 PM
rlbertrand's Avatar
rlbertrand
Haggs
Jan 22, 2021 06:33 PM
79bigred250
Mar 7, 2017 01:51 AM
88F15095F150
Sep 4, 2016 07:48 PM
bambam0718
Aug 16, 2016 05:41 PM
86FordF150Philly
Dec 30, 2015 03:44 PM
