What's wrong in this pic?
Old Dec 22, 2007 | 01:25 AM
  #31
JoeTrotter's Avatar
JoeTrotter
Is the part between the two valves in backwards?
Old Dec 22, 2007 | 02:50 AM
  #32
ernesteugene's Avatar
ernesteugene
Well I guess I won't be posting pics of my recent back X-rays. There's no telling how many more problems you guys might find there, and I've got enough things to worry about for now.
The 0.025" feeler gauge is correct for the exhaust valve, which is the single valve on the long rocker. The two intake valves on the short double rocker get a 0.015" gauge.
The guy leaning on my air cleaner is in charge, and he was using my truck as a guinea pig for teaching the other guy how to do a valve lash. The whole operation took 3 times longer than normal, but I learned all the details on how to do a complete "overhead" on a C7, including checking the torque on the rockers. BTW, I got along just fine with the boss, notice the duct tape on his finger!
I've got a quick disconnect fitting on the truck air system, and I finally rounded up all the items I need for airing up my tires. I had to slightly mod (as in bend) my wheel covers to get an air chuck and gauge to reach the valve stems on the rear wheels. I found one major air leak which used to dump the truck air pressure within hours of shutting off the engine, but the truck still looses most of it's air pressure overnight, so I've got more leaks somewhere. I discovered my windshield washer tank is broken, so I need to replace it, and I just finished replacing both rear shocks, and both batteries.
I still haven't done a trial towing test, and I'm afraid I might have to lower the king pin box on my 5er to make the trailer run level, and those bolts appear quite rusty and will be difficult to loosen. If my towing test indicates the C7 isn't up to the task, I can get a good deal on the C15 shown in the pic!
Old Dec 22, 2007 | 03:51 AM
  #33
zx250's Avatar
zx250
Of the next Riffraff East
Cool, but you still haven't told us what the problem was in the first pictures. Anybody even close?
Old Dec 22, 2007 | 04:56 AM
  #34
JLDickmon's Avatar
JLDickmon
why do you think they're called a "CLATTER" pillar in the first place?
Old Dec 22, 2007 | 08:49 AM
  #35
kawika's Avatar
kawika
If it was set correctly, you should not be able to get the feeler gauge under the rocker arm. SO..., the answer is that they had the adjustment set incorrectly for the Intake....
Dave..
Old Dec 22, 2007 | 10:22 AM
  #36
jtharvey's Avatar
jtharvey
Dave..
I concur.
Old Dec 22, 2007 | 11:40 AM
  #37
zx250's Avatar
zx250
Originally Posted by jtharvey
I concur.
Yeah, me to. (like I would have a clue) But thanks for clearing that up for me.
Old Dec 22, 2007 | 02:38 PM
  #38
guitarpicr's Avatar
guitarpicr
I concur also - but I dont have any idea to what - Talk to us Gene. BTW - Merry Christmas to all and be safe.
Old Dec 22, 2007 | 03:00 PM
  #39
maevans's Avatar
maevans
I know, No duct tape in pic......
Waiting for a answer Mr Gene.
Old Dec 22, 2007 | 04:16 PM
  #40
73f100shortbed's Avatar
73f100shortbed
Dave..
Oh yeah, that was my SECOND guess. I should have been drunk the first time and I would have noticed that
Old Dec 26, 2007 | 08:13 AM
  #41
DieselCamper01's Avatar
DieselCamper01
Bump. Anything to confirm Gene?
Old Dec 26, 2007 | 01:04 PM
  #42
SolidGround's Avatar
SolidGround
Seriously, What's the deal here?
Gene?
Gene?
Old Dec 26, 2007 | 03:48 PM
  #43
7.3L DID TD's Avatar
7.3L DID TD
Yeah, Gene what is it? Other than the fact you have already opened your engine before your first pull.
Old Dec 26, 2007 | 04:26 PM
  #44
F250_'s Avatar
F250_
I'm not sure about that. If you look closely at the guy on the right, it looks like he has duct tape wrapped around the ring finger on his left hand (either that or he has his finger through a long socket that must have at least a 3/4-inch drive opening).
EDIT... it has to be duct tape because I can see the raised section of the ring he covered up with the tape.
Stewart_H
Feb 1, 2012 11:49 PM
mustange70
Alberta Chapter
24
Mar 11, 2009 03:22 PM
PowerstrokeJunkie
19
Mar 29, 2008 08:02 PM
Snowbunny
N. California Chapter
Jan 8, 2008 07:33 AM
