Maximum CR
Old Dec 21, 2007 | 10:51 AM
69Bronc's Avatar
69Bronc
Maximum CR
On a 400 with aussie heads, a 255DEH cam, and 9.5:1 CR, would I still be able to run mid-grade pump gas?
Old Dec 21, 2007 | 12:30 PM
matts77f100's Avatar
matts77f100
At 9:5:1, running mid grade would be pushing I would think... If I were to run mid grade, it would be at only big chain gas stations with quality gas.
Old Dec 21, 2007 | 08:32 PM
danlee's Avatar
danlee
You will probably get away with 89 Octane in cool weather, if you run a 180 degree tstat. In hot weather or if you are in heavy traffic you will need 91+ octane.
Are your pistons zero deck, with a dish, or are they flattops 'down the hole'?
If they are zero deck, you will have quench, and will be able to get away with 89 Octane under most conditions.
Old Dec 21, 2007 | 10:34 PM
69Bronc's Avatar
69Bronc
I haven't picked out pistons yet. I am just trying to figure out a good build that will be nice and torquey, but also be able to run on pump gas easily.
Thanks for the information.
Old Dec 22, 2007 | 06:12 AM
danlee's Avatar
danlee
You want a set of zero deck pistons from Tim Meyer. They will allow quench which will help to reduce detonation. You should be able to go to the light side of 9.5:1 CR and get by with 89 with Aussie heads and zero deck pistons.
Old Dec 30, 2007 | 01:54 AM
roger dowty's Avatar
roger dowty
Listen close folks, as you know I just built that basic engine with aus heads, tims kb pistons and 9.5:1 ( what is atuallymore like 9.3 +-) I use the roller cam that is just a bit later IVC...not much diferent than the 255 and more forgiving if i remember correctly... I have to run retarded with 91 and lucas additive. The dynamic is pretty high with the 255 and even with quench heads and the right pistons there is no freaking way I'd go with that cam. And if you run into the 3k rpm range on the road it isnt the best cam anyway. Using the DEH 255 I'd not go over 9:1 CR.
Maybe I'm doing something wrong but even the basic guide states 95 + octane for that build...right? Hope my memory isn't going with the paint thinner i've been using lately. I'm still looking to propane the thing someday....need parts
Old Jan 1, 2008 | 04:34 PM
father/son's Avatar
father/son
mr roger, paul. for what it is worth, it is always good to hear from you in our house.
regaurdless of the issue and or the subject matter. we like your level headed stlyle, as always, it is about the MOTOR, carry on, these hillbillys are LISTENING. good luck in OUGHT 8.
quietely and respesctfully.
paul &nick kiernan berwyn MD.
Old Jan 3, 2008 | 11:36 AM
69Bronc's Avatar
69Bronc
Forgive the newb question, but what "basic guide"?
Old Jan 3, 2008 | 02:13 PM
danlee's Avatar
danlee
According to my calculations 9.3:1 static in a 400 with a 255DEH cam will give you 8.02:1 Dynamic CR. This should be OK with 91 Octane and Aussie heads with quench.
Look at www.edyno.com
gman97005
15
Jan 23, 2016 11:55 AM
CR3999!
6.7L Power Stroke Diesel
13
May 16, 2015 01:09 PM
CR3999!
28
Mar 27, 2015 08:12 AM
1978Crew
13
Oct 17, 2010 07:30 AM
zsir
Feb 14, 2003 10:22 AM
