Modular V10 (6.8l)
Sensor Locations
Old Dec 21, 2007 | 09:59 AM
jsmahan's Avatar
jsmahan
Sensor Locations
Does anyone have a diagram of sensor locations for the V-10. Trying to track down a problem. Thanks.
Old Dec 22, 2007 | 10:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Might be easier to ask for the specific sensor, or the problem itself
MAF sensor - right behind the air filter, in the air box.
TPS sensor - on the side of the throttle body.
Crank sensor - on the passenger-side, lower front corner of the engine block, right below the AC compressor.
O2 sensors - in the exhaust pipes right after the end of the manifolds.
Temp sensor - Believe it's in the back of the driver's side head?
Oil pressor sensor - front driver's side of engine block, in the oil cooler manifold.
Did I miss anything?
Old Dec 22, 2007 | 02:33 PM
Monsta's Avatar
Monsta
Sit. Stay.
Knowing the year V10 would be helpful as well...
Old Dec 23, 2007 | 10:08 PM
jsmahan's Avatar
jsmahan
Thanks guys. It is a 99 350 and I was looking for the MAF sensor. Finally found it. Using AE it was a little difficult to diagnos. The engine lopes erratically when cold with no other symptoms. Cleared codes for now and changing MAF. Thanks again for the help.
Old Dec 24, 2007 | 12:08 PM
krewat's Avatar
krewat
That sounds like the IAC.
Old Dec 24, 2007 | 12:55 PM
Monsta's Avatar
Monsta
Sit. Stay.
Changing the MAF is a bit extreme, eh?
thunder2
Feb 22, 2011 11:28 AM
KRDiesel
Jul 25, 2009 08:31 PM
lvstang
Aug 23, 2000 09:48 PM
mudinford
Jun 17, 2000 10:50 AM
PAUL_2
Dec 13, 1999 03:31 PM
