Offroad & 4x4
post your setup
Old Dec 21, 2007 | 01:09 AM
sloenuf's Avatar
sloenuf
Thumbs up post your setup
i got this idea off of another forum. everybody post up a pic or two of their trucks and list the set up. such as
Year
Make
Model
2wd or 4wd
Tire Size
Wheel Size
Lift kit size and Brand if not stock
Torsion bar Rating or Code:
Torsion bars cranked or not and if so how much.
Torsion bar keys if any
Lift Blocks?
Add-A-Leafs?
Body Lift?
Aftermarket Bumpers?
Fender Height Measurements
Any fender or body trimming needed? (If so where?)
If you see something I missed, please let me know and I will add it.
Old Dec 21, 2007 | 06:27 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
i wonder if he will come back and check if we did anything seeing thats his first post on FTE....
1978
FORD
Bronco
4wd
40" boggers
15"x16" wide
6" lift and some hella fender whackin'
torsion bars?
torsion bars are GHEY...
again with the torsion bars...
rear, 3" block and add a leaf
body lift:neg-
tube bumpers
fender trimming....
now the relevant stuff...
408, c6 w/3000 stall, 205, d44 front (again) with chomos a limited slip and 760x ujoints, 14 bolt rear with spool and chromos, 5:13 gears, 40" boggers, 16" wide wheels, bored, mild cam, eldebrock intake and 750cfm carb, long tubes, 40 series flows, etc etc etc....
Old Dec 21, 2007 | 06:39 AM
quadzjr's Avatar
quadzjr
96'
FORD
F-150
4wd
53" michelins
20"x14" stazworks db's
custom 4link front, subframe, bigass leafs rear with traction bars
no lift blocks
no add a leaf, actually ill be subtracting leafs to get a better spring ratio...
3" body lift, will be removed eventually
Aftermarket Bumpers: ill be making somthing custom to hold my MM 12000
Fender Height Measurements: ****ing tall!
the relevant part again:
a warmed up 466, built c6, np205 (with custom 4 bolt yoke) np200 hard mounted together then "soft mounted" to frame, 1410 yokes, rockwells (6.72:1), open front (for now) ouversons hubs, welded rear, full custom 4 link suspension, balistic brackets, 20"x14" stazworks double beadlocks, bling 4 wheel disc brakes.etc etc etc...
https://www.ford-trucks.com/forums/6...ld-thread.html
Old Dec 21, 2007 | 06:57 AM
fishmanndotcom's Avatar
fishmanndotcom
Year 1972
Make FORD (duh)
Model Early Bronco
2wd or 4wd 4wd
Tire Size 39.5 iroks
Wheel Size 16.5x9.75 custom double beadlocks
Lift kit size and Brand if not stock all custom, about 5
Torsion bar Rating or Code: um, no
Torsion bars cranked or not and if so how much. *see above*
Torsion bar keys if any *see above above*
Lift Blocks? none, they are evil like the monkey in the closet
Add-A-Leafs? do custom leaf packs count?
Body Lift? not an inch!
Aftermarket Bumpers? home made from thick wall tubing
Fender Height Measurements huh?
Any fender or body trimming needed? (If so where?) mucho! *see pics below*
-cutts-
Old Dec 21, 2007 | 07:19 AM
quadzjr's Avatar
quadzjr
nice as alwasy fishy!
this thread needs better info asked like gear ratio, axles, engine/tranny/tcase(s), lockers?, chromos? etc etc etc....
Old Dec 21, 2007 | 07:20 AM
RJR99SS's Avatar
RJR99SS
Year: 1977
Make: Ford
Model: f250
2wd or 4wd: why the hell would i go offroad with 2wd?
Tire Size: 44
Wheel Size: 16.5
Lift kit size and Brand if not stock: about a 6" suspension lift, no idea what brand
Torsion bar Rating or Code: I got trac bars in the rear, thats about it
Lift Blocks? The rear has about a 3" lift block
Add-A-Leafs? Dont think so....
Body Lift? About a 4"
Aftermarket Bumpers? Yep....
Fender Height Measurements: I dunno...up there
Any fender or body trimming needed? (If so where?): it wasnt needed, but the previous owner did it anyways, along with the body lift.
If you see something I missed, please let me know and I will add it: ask people how much tail the rig has got them.
Old Dec 21, 2007 | 07:23 AM
quadzjr's Avatar
quadzjr
more like gets me in trouble....
Old Dec 21, 2007 | 12:11 PM
76 F-150 390FE's Avatar
76 F-150 390FE
Year 86
Make FORD (is there anything else?)
Model F-150
2wd or 4wd 4wheel
Tire Size 33X12.5 (lookin for 36s)
Wheel Size 15X8.5
Lift kit size and Brand if not stock 4" i have no clue i pulled it off a bronco frame
Torsion bar Rating or Code: ghey i dont own a chevy or ranger
Torsion bars cranked or not and if so how much. once again ghey
Torsion bar keys if any and still ghey
Lift Blocks? only the factory block
Add-A-Leafs? the one from the lift
Body Lift? 3" was on it when i got the truck too much work to take it off
Aftermarket Bumpers? not sure if the rear is stock or not but you cant hurt it
Fender Height Measurements 41" front and rear
Any fender or body trimming needed? (If so where?) none
roller cam 302, was an AOD but now its a T-18, np208(only original drive train piece), LS44 front 3.54, LS9" rear 3.50. want to do a 460 swap but dont have the funds right now, when i go to 36s i will regear to 4.56 and probably do a SAS
Old Dec 21, 2007 | 12:17 PM
sloenuf's Avatar
sloenuf
of course ill come back haha. ive been a memeber for a little while just havent posted. nice trucks so far guys.
Old Dec 21, 2007 | 12:58 PM
78250crewcab4x4's Avatar
78250crewcab4x4
Year 1979
Make What site are we on again?
Model F-250
2wd or 4wd 4X4
Tire Size 39.5 swampers or 35 BFGs
Wheel Size 16.5
Lift kit size and Brand if not stock no lift yet
Lift Blocks? None
Add-A-Leafs? None
Body Lift? None
Aftermarket Bumpers? Hidden winch setup up front
Fender Height Measurements uhhhhhhhh
Any fender or body trimming needed? (If so where?) yes, um, the fenders about 2.5 inches all the way around
460,NP435,twin stick NP205,D44(60 is on the way),D60ls(sterling10.5 on the way), all vents run up high, 10,000lb winch in hidden setup, hand throttle, dual batteries, GOOD tow hooks front and rear, 10mpg, CB, I need to gear it down from 3.73s for the 39.5s. And it tows a samurai.
Old Dec 21, 2007 | 01:07 PM
DesertStorm's Avatar
DesertStorm
Year-1993
Make-Ford
Model-Ranger
2wd or 4wd-4x4
Tire Size-38.5x11xr15 boggers
Wheel Size-15x8
Lift Kit size -6in skyjacker
Lift Blocks -came with kit
Add A Leafs- came with kit
Body Lift-3inch
Fender Height Measurement-around 48/49ish at top of arch (big for a damn ranger)
Trimming-the tires do it for me
extra info-4.88 gears, soon to be lincoln locked in the rear,4.0v-6, 5 speed,headers,2.5" dual exhaust with flowmasters, custom watertight intake
Old Dec 21, 2007 | 01:30 PM
4xsport03's Avatar
4xsport03
Year: 2006
Make: Ford
Model: F250 PSD CC Sport
2wd or 4wd: 4x4
Tire Size: 37x12.5x17 BFG
Wheel Size: 17x9 MM
Lift kit size and Brand if not stock: 6" BDS
Any fender or body trimming needed? No
15,000 Warn winch
Old Dec 21, 2007 | 01:37 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Since I miss my old truck so much (I nearly CRY every time I think about it which means I carry tissues with me everywhere!!), would it be OK to list it here? Cutts knows what I mean!!
Old Dec 21, 2007 | 01:40 PM
76 F-150 390FE
go fer it, it was one hell of a truck
Old Dec 21, 2007 | 01:48 PM
quadzjr's Avatar
quadzjr
NO YOU CANT!!!!!!!!!
