Bronco II Ford Bronco II
Need Help
Old Dec 19, 2007 | 07:19 PM
snowmobile's Avatar
snowmobile
Question Need Help
Just got an 85' bronco II the engine temp. gauge stays a hair pin from the overheating mark so at or almost touching the highest piont in the norm level is this normal? what can I do to keep the temp. in the middle?
Old Dec 19, 2007 | 09:17 PM
McQue's Avatar
McQue
Start with a complete flush of the coolant system, clean radiator fins, get a new radiator cap with proper pressure rating, change thermostat, inspect water pump....
refill system with new coolant at proper mixture...make sure your system has no leaks and is completely intact, with no air trapped in system...You may want to change hoses and clamps if they look old or soft...flush out heater core while your at it....
Old Dec 20, 2007 | 04:17 PM
rebocardo's Avatar
rebocardo
You might want to put a real gauge on it to make sure the factory one is accurate.
jobguy
Escape & Escape Hybrid
Feb 28, 2012 04:17 PM
nurse47557
1997 - 2003 F150
Jan 15, 2005 10:02 PM
restorit
Electrical Systems/Wiring
May 9, 2002 10:32 PM
dave thomas
Oct 1, 2001 11:07 AM
brucef
Feb 21, 2001 08:08 PM
