300 inline electrical problems
Old Feb 2, 2001 | 09:20 AM
jparish's Avatar
jparish
My 1986 F-150 with a 300 inline six has continuing electrical problems. The battery loses charge over a few days driving and then the whole thing shuts down. I've done all the normal things to fix this including: replaced alternator (with built-in voltage regulator), replaced battery, replaced battery cables. Nothing seems to work. Any and all advice is greatly appreciated. Thanks!
Old Feb 2, 2001 | 06:59 PM
trouble's Avatar
trouble
Have you checked your battery for a draw while everthing is shut off. You could have a short somewere drawing your battery down.
Trouble
Old Feb 2, 2001 | 11:12 PM
rpickle's Avatar
rpickle
Well, here are a few suggestions. First, find out whether you have a short to ground. Use a voltmeter and run one lead to the negative post of the battery and the other to a good ground (engine and ignition off). If there is any voltage, you have a problem. You can also do this with the engine on. Second, make sure all connections to the battery, alternator and started are clean and tight. Thirdly, check that your new alternator is putting out sufficient voltage. I believe that at idle and minimum load, the voltage at the battery should be around 14.5 volts. These aren't in any particular order. Hope you find the culprit soon.
Rick R.
1984 F150
300 6 59000 miles
No frills pick-up!
Old Feb 3, 2001 | 08:00 AM
Willie's Avatar
Willie
You might have the ignition module checked out. I had a simular problem with my 85 when it was brand new and they had to replace the module twice.
Old Feb 3, 2001 | 07:53 PM
fordiesel69's Avatar
fordiesel69
ChrisGray91
Aug 25, 2014 01:54 PM
Wyatt's1988
1978 - 1996 Big Bronco
Jan 8, 2010 07:44 PM
dadsford
Sep 16, 2008 08:04 PM
lemcham
Engine Swaps
Sep 8, 2007 04:01 PM
rttamaman
Apr 5, 2004 05:05 PM
