460/NP435 combo?
Old Dec 19, 2007 | 06:20 PM
akaFrankCastle's Avatar
akaFrankCastle
460/NP435 combo?
Just curious as to whether or not it is possible to bolt up an NP435 to a 460 Ford big block. If so, what applications do I need to look for to acquire a bellhousing?
Old Dec 19, 2007 | 06:53 PM
76 F-150 390FE's Avatar
76 F-150 390FE
its possible, you can find a bell housing from any 351M 400 or 460 with a 4speed
Old Dec 19, 2007 | 07:58 PM
akaFrankCastle
good deal. I just didn't know if the 351M/400 bellhousing bolt pattern was the same as the 460.
Old Dec 21, 2007 | 01:57 PM
cmbroo1's Avatar
cmbroo1
yes, I am bolting up a 435 to a 400 right now and recognized the part numbers to applications. A 400 and a 460 bell housing is the same. If you find a bell housing I would junk yard it. ALL of the yards we went to had them already pulled off. I also know the fly wheel is the same for a 351m/400 and a 460. I dont know about the clutch. Dont know what your going from motor and tranny.
Old Dec 23, 2007 | 04:05 PM
Hyperactive460's Avatar
Hyperactive460
the 351m/400 flywheel won't work on a 460 crank. i used a 360/390 flywheel as well as 360/390 clutch for my conversion. just use a quality clutch kit. i also had a pilot bearing machined to fit deeper into the crank for proper fitment.
Old Dec 24, 2007 | 08:30 AM
cmbroo1's Avatar
cmbroo1
well sorry but in LMC the flywheel part number were the same for the 351m 400 and the 460. But I was a little curious because when I held the clutch up to the flywheel it was only about 1/4" away from the bolts on the outside. And that was with a 12" clutch.
OzFTrucker
Nov 30, 2013 04:25 PM
ManfredVonRichtofen
WTB - Parts & other
Nov 13, 2013 02:50 PM
oldhalftons
Jun 30, 2004 10:23 PM
Ratsmoker
Jun 23, 2002 09:35 PM
jowilker
Jan 17, 2001 09:55 PM
