FICM Relay Location???
Old Dec 19, 2007 | 10:27 AM
b_dub's Avatar
b_dub
Truck didn't start the other afternoon, cranked but no start. I noticed that the fuel pump wasn't cycling before I engaged the starter. Reset inertia switch didn't do anything. Then I checked some fuses and relays, none of them were bad, and it started. Got home and scanned it, and it came up with FICM Relay voltage too low. Where is the stupid relay?
Thanks
Old Dec 19, 2007 | 09:35 PM
3000 FPS's Avatar
3000 FPS
The relay sits inside the Battery Junction Box. It is located under the hood on the drivers side next to the the ABS control module. It is going to be one of the square relays in the corner inside the box. The box is close to the firewall. On the top of the box it has the relay designations. The relay number is 304.
bigbeariron
Sep 24, 2020 07:49 PM
joejackF250
Apr 29, 2015 09:05 AM
softpickle
Feb 14, 2015 11:58 PM
madmatt1186
Feb 2, 2015 11:00 PM
TL53ford
Dec 22, 2012 10:06 PM
