Hissing Sound
Old Feb 11, 2001 | 08:05 PM
matt davis's Avatar
matt davis
Hissing Sound
Ive been driving the truck i bought know for about 1 month and love it,well except the gas mileage.I noticed that when i shut it of after running it awhile that i get a hissing sound under the hood somewere and cant seem to locate it.seems to be up near the firewall somewere and it stops after about 5 or 6 seconds does anyone know what this is or should i not even worry about it .thanks
92 F150 2wd 5 speed 2.73 rear
Old Feb 12, 2001 | 01:12 AM
PAUL_2's Avatar
PAUL_2
Hissing Sound
It could be just a normal noise , My 300 has made the same noise when I shut it off for the last 10 yrs . The charcoal canister also makes a noise when the engine is shut off that sounds like a rattling noise , thats just the check valve making the noise & its normal
Old Feb 12, 2001 | 08:52 AM
billyb's Avatar
billyb
Hissing Sound
maybe it is a cobra engine!!
Old Feb 12, 2001 | 11:07 AM
matt davis's Avatar
matt davis
Hissing Sound
Could be You never know!!
Old Feb 14, 2001 | 07:37 PM
otto's Avatar
otto
Hissing Sound
Old Feb 15, 2001 | 02:47 PM
paulg's Avatar
paulg
Hissing Sound
Are you running the AC at all. My AC did the same thing. I was told by several mechanics this is normal for the truck. Next time listen by the AC compressor and see if the sound is coming from there.
Old Feb 15, 2001 | 03:53 PM
billyb's Avatar
billyb
Hissing Sound
matt, short of killing the cobra, check to see if your ac is on or if the defroster is on. either setting can cause the ac compressor to cycle. you will be pressurising the system while driving. also see if you have a small unit an the top side of fenderwell on passenger side. it looks like a fan setup, and it runs after you shut off engine( at least on my 88, anyway). it ventilates the fuel intake somehow . mine will run for a short time after shutting engine off.
frenchf250
Modular V8 (4.6L, 5.4L)
Jun 10, 2024 02:30 PM
airborne89
2004 - 2008 F150
21
May 18, 2017 08:40 PM
arrowheadfred
May 17, 2010 08:54 AM
matttomlinson
Dec 8, 2009 05:25 PM
Ryan T
1997 - 2003 F150
Apr 2, 2007 06:00 PM
