Aerostar Ford Aerostar
repair manual
Old Dec 18, 2007 | 01:43 PM
green bean's Avatar
green bean
repair manual
which manual should i get ,Haynes, chiltons or. 93 awd 4.0 litre. I think its time to do the heater core. Smelling the antifreeze.losing a little coolant.73000 miles
Old Dec 18, 2007 | 02:25 PM
96_4wdr's Avatar
96_4wdr
Ford Svc cd on ebay, best of the lot for the money
can print out pertinent pages and have them under the hood while working, grease no problemo, just reprint
Old Dec 18, 2007 | 02:31 PM
VanGo's Avatar
VanGo
Yeah that. ^^
The only downside is you have to boot up to read it.
Old Dec 18, 2007 | 08:05 PM
93nighthawk's Avatar
93nighthawk
Go with either the factory CD or go with the Factory manuals off of e-bay. That is where I got my set and it is so much more detailed compared to haynes/chiltons you won't believe it. Almost every procedure is detailed with pics/drawings, and they have alot less errors.
Old Dec 18, 2007 | 08:52 PM
green bean's Avatar
green bean
i looked at the factory ones on e-bay. All I saw were for all fords within the year mine is. Supposedly covers them all.Is that the one I want
Old Dec 18, 2007 | 09:08 PM
93nighthawk
Are you talking CD or Book?
If CD, then yes, if book, then no.
Old Dec 18, 2007 | 09:19 PM
96_4wdr's Avatar
96_4wdr
i'll have the Ford Truck with '93>'94 and '96 Aero .iso cd images up on my website whenever Comspastic learns how to upgrade their web site system to the new 1 gb limit.
they've been at it 2 months and it only gets worse.
Old Dec 19, 2007 | 02:44 AM
xlt4wd90's Avatar
xlt4wd90
Replacing the heater core has been discussed here a couple of times, and should turn up if you do a search.
However, if you can't find it, here is the condensed version:
1. Drain the coolant.
2. Separate the hoses from the core. This has been done a couple of ways, but the correct way is to get the proper tool from Ford to release the plastic tabs from the spring-lock fittings. Someone has successfully done this with a long nose plier that has a 90 degree bend at the end. The trick is to push the hose into the core nipples to give the spring clips clearance to be pushed away from their latch points. If your cooling system is very dirty or corroded, this may be very difficult. So some people, like me, just cut off those plastic ends and pushed the rubber hoses onto the nipples, and held them on with regular hose clamps. You may need to install short hose extensions for this modification.
3. Open the heater box. Someone did this by removing the glov box to get at all the bolts that hold the heater box together. I removed the lower panel of the dash, but this could be difficult if you have a graphic equalizer.
4. Assembly is the reverse, with the possible exception of the hose connections. You need to keep the foam rubber surround of the old heater core and re-install it with the new one to help seal it to the box.
Old Dec 19, 2007 | 04:03 AM
Pablo-UA's Avatar
Pablo-UA
Repare manual say, that I dont need to remove a glovebox, but a little monkey can remove heater cover there. I had to remove lower part of dash....
Old Dec 19, 2007 | 05:20 AM
Pablo-UA's Avatar
Pablo-UA
Sometimes sevrice manuals are writen like for down sindrome kids. Other manusls are for idiots, theirs author understand, that idiocy is very creative and describe absolutle idiotic ideas and say to you DO NOT DO IT....
Old Dec 19, 2007 | 05:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Shop manuals
Factory shop manuals in printed form.
helminc.com Helm has been the printer of Ford shop manuals since the 1940's.
faxonautolit.com Factory originals & reprints of originals.
Faxon also sells: sales brochures, owners manuals, parts catalogs, accessory brochures and Ford Dealer Data books.
Tron75
Jul 15, 2013 06:47 PM
mdcyr
Modular V10 (6.8l)
May 13, 2008 04:05 PM
bronco2454
Bronco II
Jul 14, 2006 07:46 PM
MJEmerson
2004 - 2008 F150
Dec 24, 2004 11:17 AM
Jmatteau
1983 - 2012 Ranger & B-Series
Apr 10, 2003 05:53 PM
