Cruise Control
Old Dec 19, 2007 | 10:03 PM
MADVAN's Avatar
MADVAN
You could get and install the OEM switch. It will make the system active.
Just will not work as a backup until you change the master.
Bill
Old Dec 19, 2007 | 10:16 PM
Flea's Avatar
Flea
Madvan, I am a bit confused by your message.
When you say
"primary is your brake light switch" what do you mean.
By the way I found that my third brake light doesn't light up at all with the brakes.
I should check the bulb but if it isn't how do I fix this.
Am I walking a fine line by just jumping the cable coming out of the PDB?
Thanks for you help.
Fletch
Old Dec 19, 2007 | 10:20 PM
Flea's Avatar
Flea
"You could get and install the OEM switch. It will make the system active.
Bill
What does this mean?
What is the OEM switch, which switch? Do you mean the mc switch included with a cc mc?
Fletch
Old Dec 20, 2007 | 08:35 PM
Flea's Avatar
Flea
Still trying to get the third brake light to work.
Any ideas?
tom from mass
Feb 4, 2014 02:21 PM
Krisx125
Apr 4, 2011 12:05 PM
yorxs
Aug 14, 2003 12:56 PM
yorxs
Aug 4, 2003 10:41 PM
