cheaper hpop fix
Old Dec 17, 2007 | 03:06 PM
seanz's Avatar
seanz
Trailering
cheaper hpop fix
So I found something out when replacing my HPOP seals. You can order the kit with three o-rings for around $25 or you can just order the quick connect clamps for $8 a piece that have the orings on them. Ford will sell you the metal clamps with the o-rings cheaper than the o-rings by themselves. Figures.
Old Dec 17, 2007 | 03:27 PM
ggirten's Avatar
ggirten
You don't have a Ford # for those do you?
Old Dec 17, 2007 | 03:43 PM
seanz's Avatar
seanz
Trailering
part number
The part number is F81Z-9C402-AA
And you can use a cheap door removal tool to remove the clamp, then a socket and extention to get the rest out.
Old Dec 17, 2007 | 07:05 PM
F350-6's Avatar
F350-6
That's good information. Rep points given.
Thanks.
Old Dec 17, 2007 | 07:13 PM
guzzle92's Avatar
guzzle92
Does this kit come with the 'special' thread sealant LocTite stuff?
Old Dec 17, 2007 | 07:36 PM
seanz's Avatar
seanz
Trailering
It is not a kit. It is just the quick release pieces that screw into the HPOP and release from the oil lines with new 0-ring gaskets. I had locktite in the garage. In my excursion, the drain plug was not leaking. It stops you from buying the kit if you only have a leak in either the line or the plug. You don't have to pay $25 and hold on to the other o-rings until they start leaking. If you loose an o-ring, break one, or just want to replace the one that is leaking, this gives you another option.
ron's power stroke
20
Dec 8, 2011 02:11 PM
kudunk06
Oct 27, 2011 11:05 AM
blake 7.3L
Aug 11, 2009 05:00 PM
Truck207
Mar 17, 2009 10:21 PM
wlihntr
16
Feb 7, 2008 09:24 AM
