He's saying that individually the cylinders on a 300 have more cubes per cylinder than a 390 does......not saying the cubic inches of the V-8 are smaller just the volume of the cylinders.
well like i said i have decided against the 390, gonna save that for a car project in the future. i know where i can get a used complete 300 for $400. is this a good deal? also how much would it cost to have the guy put it in also?
I've got two I6's, and their both awesome motors, one with 235K miles and is my daily driver, motor's not been touched besides seals. The other is pretty much a parts truck, but it has 160K miles and will be a donor motor IF this one ever blows.
The longetivity thing is nice, but I'd rather have a 390 with a C6 behind it any day. In 1968 these motors were rated at the factory with over 300 horses, and gobs of torque. You can add a power package from edelbrock and make 418 horsepower and 434 ft lbs. of torque with a stock bottom end...imagine that!
Id go with the older one just because the solid axles 390, c6 combo makes for an excellent platform to start from. cheap and easy to build. unlike these newer trucks. and even easier to work on.
That's alright...the younger you learn from experienced people the more better(redneck term) knowledge you'll have.....rather have ya learn it the right way than the wrong way.....Later On
mainly ill use it for a daily driver, but i pull alot of various things. i to would love to have the 390 but i have $800 to spend on a motor plus what ever else i need.
I built a 390 in a '67 F-100 I drove for awhile that got 14mpg with 3.25's and a Holley 1850. If you trash the low compression pistons, add an RV cam and the little Holley you will have gobs more torque than you ever will with that 300 for the money. Now, if you want a stock daily driver go with the 300, my father's 93 has 250,000 now, never burns oil.
