Next Question
IIRC, It doubles as an oil slinger.
The dowel that is supposed to hold it in one place could have broken off but I have never seen one that did,.
I'll try and find a pic
I talked with my better half about doing a replacement of the timing chain and gears. The cost is not that great for the gasket set and the timing set for this engine. (heck, we already planned on replacement of the waterpump...again, part cost is not that much even for a new in box one) So we will already be in the same area-code as the timing cover.
At that time I'll inspect the eccentric for excessive wear and broken parts. I know some will say "Why replace it if it's not bad?" Well...Considering the fuel pump is the factory one, with over 30 years on it? What would anyone consider the odd's to be that the timing chain/gears and waterpump have ever been changed in that 30 years? Besides I'd hate to replace the hoses, flush and re-fill...only to find the waterpump is craped...or go that far into it? And having the timing chain give out. If we are going to go that deep? Might as well go all out.
Now there is a possible issue with the 'Carter' replacement pump being defective. It would not be the first time to replace a defective part with one junk out of the box. And the other two where just visual compaired to see the difference with the pump arm. So, just to keep the peace? Bosch does manufactor a replacement pump for the engine. I'll see if I can order one in one of that brand (the photo ID from the website looks like the cam-arm more matches what we removed..the carter and other manufactor? The arm does not match up fully)
S-
I also googled and fruggled every ID number off that pump--Came up goose-eggs. What is the Carter number? I MAY have cross references to Ford numbers.
So the electric pump was the only real option. I hate using it, as I would love to keep things as stock as possible--But this one has me scratchin' my head.
S-
> > > 1973/76 F Series Truck 360/390 Fuel Pump UPDATED Ford part number: D8TZ-9350-C / The ONLY one the Ford parts catalog shows. < < <
Have NAPA cross the Ford fuel pump part number over to the brand they sell. See what number they come up with.
Did'ja know that on each sending unit there a replaceable filter screen? It's not the same one as Mil1ion posted the pic of. The Ford filter screen is black plastic with a partial mesh arrangement. If the filter screen(s) are clogged up, all the new fuel pumps in the universe won't help a bit. When those filters clog, the truck ain't going anywhere. The filter is still available from Ford and autoparts stores. The size is 3/8" in diameter.
I say again, 3/8" diameter....not 5/16"...that's the size for Pinto's and Mustang II's. If buying from Ford, all you need is the part number, but autoparts stores may sell you the wrong one, if you don't tell them the diameter.
D1AZ-9A011-A .. Filter Screen
C0AF-9276-A .. Sender Gasket
Now is the time to replace the fuel sender float. The floats are the same from 1957 thru 1979. Gas gauge no workee? The floats are made from two pieces of copper soldered together. Solder breaks down, gas seeps into float...float sinks to the bottom of the tank.
C0AZ-9202-B .. Fuel Sender Float
Available from Ford, autoparts stores.
S-
S-
Pic sez Super Cab, but that might be an printing error.
Also: Section 90 / Page 8.
I think Ford goofed in their listing of Super Cab & S/CS in these pics.
Regardless, the systems should be close to what non Supercabs and S/CS's use.
Parts catalogs aren't assembly manuals, the numbers are only shown for parts identification for us numberdummies.
Anudder = prolly similar: Section 90 / Pages 29 & 30.
D0AZ-9350-D / DOTZ-9350-A / D4TZ-9350-A / D4TZ-9350-B updated to D8TZ-9350-C < < This is the same pump used on 330 U-Haul trucks.
S-
I wanted him to pick which one he thinks it is
Then and ONLY then Since I have OSI parts books up until 1984 I will look for a newer part number.
Otherwise IMO it is a waste of my time to GUESS.
Some Genuine Ford Parts are still available from Ford for the 1950's & 1960's models.
More for 1970's and much more for 1980's and 1990's models.
If you want older Ford parts all you have to do is ask about them here on FTE.
Besides the big dummy, there are other FTE'ers that can help with part numbers. and...
Before visiting the aftermarket suppliers. FTE has two Ford dealer parts department sponsors.
Both give discounts off the Ford suggested retail price to members.
> > > DIRECT FORD PARTS - Gaudin Ford Las Vegas NV / Y2KFORDPARTS - Millennium Ford Seattle WA.
Their links are on the forum main page.
FTE sponsor GREEN SALES sells Ford obsolete parts - greensalescompany.com.
At the very least? If they have the fuel tank straps for the middle tank? Sold American! If they can beat the cost for the middle fuel tank? I'll buy from them without a second thought.
I am very honored to have gotten such response to this major pain, My better half stated the electric pump would be fine...however with my luck and time spent working with electronics? (primary job is a tech for a video arcade company) I know they love to fail at the worst possible time. And heck, the factory pump lasted 30 years! That does say something about ford's "quality" back in the day. (not sure how their quality is in recent years, I've not worked as an automotive tech in 15 years...but I love to get my hands dirty on our own cars and such)
S-
What I do is once the part number is known, I search the web and if the parts can be found, I post the results.
I addition, I've dealt with Green Sales for almost 40 years. They are the best source of 1970's obsolete parts on the planet. All their ppl are former Ford parts counter persons. They care, too...unlike most of the Ford dealers parts help today, most of which don't know diddly-squat and could care less.
> > > 360/390 Fuel Pumps = GREEN SALES shows 10 each new Genuine Ford Parts: D8TZ-9350-C & D4TZ-9350-A.
D4TZ-9350-A is replaced by D8TZ-9350-C, so either will work on your 1975.
And I found one salvage yard that deals with trucks only? Knows when he thinks he's got people by the short-hairs. Sorry bud--I'm not sending your children to college this week. LOL.
S-
And I found one salvage yard that deals with trucks only? Knows when he thinks he's got people by the short-hairs. Sorry bud--I'm not sending your children to college this week. LOL.S-
What's really sad is out here in La La Land, the rust free sheet metal goes to the scrapper daily.
No rust, so we have a bumper crop of primo sheet metal.
If you can't find the fuel tank, I have one local source that I know can help.
The problem is, it's here in Los Angeles.
