Truck from cali any different?
Guys would you be able to run a carfax for me asap? The vin is 1FTSW31F03EA58130
need help guys.
thanks
need help guys.
thanks
Originally Posted by CSIPSD
You can register any road legal rig in Ca if it has all the equitment it came with from the factory...
The injectors on the SD trucks are all the same from late 99 to the end at 03... AD's with a AE LL injector on #8... No other differance other then the tuning and the GPC...
Originally Posted by 95Z71
thanks for the replies, don't mean to sound ignorant, but what is the AD and tuning and GPC?
GPC is a Glow Plug Controller, an expensive little bugger that Cali and excursions had... Takes the place of a cheaper GPR. Glow Plug Relay
Originally Posted by wlihntr
i have never ever ever heard that..please elaborate??
page 303-04C-5, 303-04C-6, item # 16 FPN 9F593 Calif fuel injector (rate shape)
Identification #14 ref # 13 CA ident only yellow clip
also referring to item 11, spill control port (ca only) (part of 9E527)
apparently, (although I cannot find the @#$^&* ) reference the difference is they modified the tip and spill control port. Ford claimed it flowed better and didn't drip bypass fuel somewhere into the cylinder when I had one of the vapid things (#8) replaced under warranty, and CA EPA says it reduced emissions when Ford couldn't/wouldn't install P/n 9E527 in LA APCD.
They also come in LL style of #8 clicky injector noise supression. the picture above shows the yellow clip identifier.
Originally Posted by medhvac
i think this is that LL injector!
Yes it is... and a nice shot of the AB injectors that come in a early 99... Someone added the LL to your truck at a later date as they did not come in the early 99's unless someone complaned about the noise. Also the two injectors I see are remans... Hence the R on the top...
