check engine light
Old Dec 16, 2007 | 06:16 PM
65fordguy's Avatar
65fordguy
check engine light
I just bought a 2001 f150 super crew 145k miles...mint condition...however my check engine light has come on twice...with about 75 miles between each.
The truck runs and drives fine, no knocks, pings, pongs, clunks, misses, nothing. no signs for me to follow.
Any Ideas?
I checked the MAF, not sure if it was clean or dirty...more than likely dirty...
The truck came with a K&N air filter in it so I think it might have oil on the sensor???
My only other guess was the o2 sensors....but im pretty ignorant as to what goes on down there.
Im trying not to go spend a few bucks at the ford dealer just to read a code. just for it turn up with a dirty MAF or a faulty sensor. This is my first modern ford to own... so if any of you guys have had the same issues. let me know how you fixed it and what the prob was.. Thanks!
Old Dec 16, 2007 | 09:16 PM
65fordguy's Avatar
65fordguy
Just went to autozone and had them do a obdII check...
It came up with a PO430 code.
Catalyst system efficiency for bank 2 is below threshold for the
engine operating conditions.
Any fixes?
Old Dec 16, 2007 | 11:04 PM
LxMan1's Avatar
LxMan1
Most of the time it is a bad O2 sensor.
It is the one behind the cats on the drivers side.
Old Dec 17, 2007 | 07:18 AM
projectSHO89's Avatar
projectSHO89
Catalyst efficiency codes are usually not due to O2 sensors as the sensors are well tested for proper operation before running the efficiency monitor program.
Probably a dead/dying cat.
Steve
Old Dec 17, 2007 | 07:48 AM
65fordguy's Avatar
65fordguy
So is there an underlying issue killin my cat? or is the 148k miles just time for a new cat.
Old Dec 18, 2007 | 10:05 AM
LxMan1's Avatar
LxMan1
HMM, most that I have had that had this code, had a 0.00v reading on the scanner.
I guess scanning it with a live data scanner would verify this.
Old Dec 18, 2007 | 06:03 PM
projectSHO89
A [i]graphing[/1] scan tool definitely will show a dead (inactive) cat in a heartbeat. Both the upstream and downstream O2 sensors (per bank) will be switching in near unison indicating that the cat is not working.
Steve
Old Dec 18, 2007 | 06:06 PM
73f100shortbed's Avatar
73f100shortbed
Steve
I agree. It is a good idea to replace the 02 sensors when replacing converter though, IMO. Problem is most likely the cat though.
jakeybob
1983 - 2012 Ranger & B-Series
Jun 3, 2010 11:17 AM
ford2002f150
1997 - 2003 F150
Mar 29, 2008 08:12 PM
FastEdsel
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 14, 2005 11:25 PM
case2k5
Modular V8 (4.6L, 5.4L)
Sep 18, 2005 05:20 PM
funnyperson1
May 27, 2003 12:01 PM
