Sponsored by: Real Truck
4 wheel drive problem
Old Dec 15, 2007 | 10:36 PM
shoobear's Avatar
shoobear
Hey i have a 2005 F350.
I have the hubs in the Auto position.
I turn the switch into 4wd....it goes in to 4wd....i drive for about 30 secs and next thing i know the rear end is sliding out on me! Back to 2 wd in a snow storm on a wicked hill! The light is still on but not in 4wheel. I turn the **** back to 2wheel and then back to 4wheel and its in again....another 30 secs and its out again....
ARGGGG....only in a wicked canada snow storm!
Anybody have this happen?
Tomorrow i will try it in the Lock position and i dont think i will have a problem.
I will look for wires loose and any vac leaks also.
Im thinking the vacuum solenoid......?
Old Dec 16, 2007 | 02:53 AM
5.4L to Freedom's Avatar
5.4L to Freedom
Well sounds like the typical ESOF hubs problem to me. Easiest way to fix this is to get ur @$$ out of the warm cozy truck and manually move the selector on the hub to "Lcoked" if this selector is seized, which is common, try some PB blaster to free it up. Prolly wont work...
ANyhow, probelm is best corrected with a set of Warn 11690 manual locking hubs. Once they are locked in, they are in. None of this in and out crap.
Old Dec 28, 2007 | 05:52 PM
shoobear's Avatar
shoobear
yep,
locked the hubs in and not a problem since!
Think i will get a set of warn hubs in the future. I use my 4wd everyday!
Old Dec 28, 2007 | 06:11 PM
zx250's Avatar
zx250
Of the next Riffraff East
Warns are a good idea, but you didn't ask that. Your problem is most likely a vacuum leak somewhere. Your air probably goes to defrost abou the same time you hubs unlock. Search ESOF and you will find all the fixes, and places to check.
Old Dec 29, 2007 | 12:14 AM
WildWildWest's Avatar
WildWildWest
Warn isn't making the hubs for the 2005 and up yet to my knowledge. You can only get them for models up to 2004.
I considered going this route when I found out my hubs were seized when I bought my truck, but I went back to the dealer and he cut me a sweet deal on a pair of brand new factory hubs for the front end (only one was seized, but the other one was tight). I didn't have a problem paying half price for both and getting new ones that I put in myself. The guy who owned it before never turned the hubs regularly and they had seized up - didn't notice when I bought the truck because I just turned the hubs on one side - the side that was tight, but not seized.
IHdieselfan
Feb 1, 2014 08:55 PM
Enduroman
29
Dec 20, 2011 06:09 PM
UglySinceBirth
15
Feb 15, 2010 12:01 PM
DieselJr
Jan 28, 2010 12:14 PM
odinmurphy
Jan 29, 2002 05:54 PM
