surging
Old Mar 8, 2001 | 07:19 PM
donald's Avatar
donald
surging
I have a 89F150 4x4 with the 300. It is a new jasper with virtually everything replaced on it. When it is cold out and it is first started it runs fine for about 45 seconds and then it starts surging and will usually die. If it doesn't die it will quit after a few minutes. I took it to a very good mechanic and he replaced the idle sensor, computer, cleaned the throttle body and a few other things I can't remember. He said that there is a sensor for the temperature but it checked out ok. He is stumped. I'm out a lot of money and still have a truck that doesn't run right. Any suggestions?
Donald
Old Mar 9, 2001 | 05:11 AM
kassonb's Avatar
kassonb
surging
Did you change the fuel filter?
Old Mar 9, 2001 | 04:53 PM
donald's Avatar
donald
surging
Not lately. It has about 30,000 miles on it since I last changed it.
Old Mar 13, 2001 | 05:36 AM
kassonb's Avatar
kassonb
surging
Recommendation is to change it every 10,000. Mine was surging (EFI) and a new filter stopped it.
Good luck.
Old Mar 13, 2001 | 12:10 PM
PAUL_2's Avatar
PAUL_2
surging
Was the engine checked for intake leaks ? When it dies check the fuel pressure & whether or not it has spark . How old is its TFI Module ?
Old Mar 15, 2001 | 06:40 PM
donald's Avatar
donald
surging
What is a TFI Module?
Old Mar 15, 2001 | 09:09 PM
rpspwp's Avatar
rpspwp
surging
TFI = Thick Film Integrated ignition module. It is right on the base of the distributer. My experience is that if this goes bad, it won't start at all. Mine decided to go at a pitstop in Coalinga, CA in the middle of a trip from Seattle to San Diego. Good thing there was a Motel 6 right there. Anyway, mine also has a problem with hesitation/stumble. I found a tech service bulletin on the Mitchel Repair CD ROM that addressed it. It wsaid it can many times be caused by the EGR opening up too fast going from a stop especially when it is cold out. It details a fix that has you install a ported vacuum switch in the thermostat housing which prevents the EGR from getting vacuum until the coolant is warm. It gives ford part numbers of the things you'll need right in it. I haven't done it yet for other reasons (money/living in warm SoCal) and I can live with it. It only does it very briefly so if I just push it the clutch and take it easy for the first few minutes, I am fine. It probably applies to your injected '89 as well. I can send you a scanned copy (and anyone else too) if you email me at rpspwp@home.com. Good luck.
Will
'84 F150
YFA F/B
SROD
"Ex" => Bone Stock
Old Mar 15, 2001 | 09:17 PM
rpspwp's Avatar
rpspwp
surging
It could also be a problem with the EGR itself sticking open. You may want to pull it off and knock the carbon off the seat or just replace it all-together. When I swapped mine after failing a smog test in '94, they gave me a different style that used an extra diaphram btwn the EGR solenoid and the EGR valve. It is a back pressure transducer type EGR that uses exhaust pressure to modulate the vacuum signal to the EGR so it opens/closes more smoothly. Just a thought.
Will
'84 F150
YFA F/B
SROD
"Ex" => Bone Stock
Old Mar 16, 2001 | 07:57 PM
donald's Avatar
donald
surging
The EGR was found to be bad and was replaced. Thanks for the help. If you think of anything else please let me know. Thanks.
Don
Old Mar 20, 2001 | 11:22 PM
toddmiller's Avatar
toddmiller
surging
Not sure if this is the same thing or not but, my 87 F-150 was surging and running like crap, numerous "good mechanics" with the computers telling them the "MAP sensor was out of range", but they knew better because those things never go bad. After I got tired of the experts I was refered to a friend of a friend who worked at Ford and had a used MAP sensor laying around, we plugged in the new one and Problem Solved! Sometimes the "experts" experience is their worse ememy. Hope this helps.
Old Mar 29, 2001 | 03:08 PM
bigred89's Avatar
bigred89
surging
I have had the same problem w/ my 89 F-150, 300-I6, with 115,000 miles on it. (Up in the cold MI climate) The problem started up right around 100,000 mi (engine overhauled at 95,000). I've found that the best fix is to start the truck, and when the surging starts, I get on the gas and hold the engine at about 1500 RPM for another 30 seconds to a minute. After that it'll idle down fine.
Old Mar 29, 2001 | 08:03 PM
92fordflareside's Avatar
92fordflareside
surging
Donald Edmonton
2009 - 2014 F150
16
Nov 7, 2012 11:24 AM
DCaillouetJr
Jan 7, 2011 08:20 PM
dcrewchief
Oct 21, 2004 11:48 AM
Donald Rager
Aug 31, 1999 01:16 AM
