Installing headers
Old Dec 18, 2007 | 12:48 PM
78bigunns's Avatar
78bigunns
Originally Posted by Conanski
You'll wanna see these pics then. I built this using 2 mentrel bent J bends, a 2 into 1 collector and a couple header flanges. I welded it all together with my Lincoln wire feed welder, it only took a weekend to complete.
http://www.flickr.com/photos/motorstuff/sets/72157602458567072/
P.S. I moved the muffler up behind the cat as the locaton shown was too loud inside. It's much better that way and still sounds great outside.
Can you come down to Virginia nad help me put mine together? I have a MIG here already.
That is the part that keeps me from going out and buying stuff and fabbing it together.
I think trying to lay it out and get it right just might make me nuts..........
I want to put on longtubes.......
Old Dec 18, 2007 | 01:09 PM
Conanski's Avatar
Conanski
We toured up and down the Blue Ridge Parkway a couple years ago on the bikes and I have been dying to get back down there ever since. That's one awesome stretch of blacktop right there.
That is the part that keeps me from going out and buying stuff and fabbing it together. I think trying to lay it out and get it right just might make me nuts..........
Yeah.. it a job for sure. I started at the header flanges and worked back, cut a section from the J bend and tacked it on to test fit, and then fully weld it once it's right. I'm sure I bolted and unbolted each side of the Y assembly dozzens of times as I built it up. But on a nice summer day with some tunes playing in the shop.. some cold beverages in the cooler... what could be better than chopping and welding up some pipe to make the truck sound and perform better. This setup easily outperforms the job a local muffler shop did a few years ago for me, they used a hydraulic bender and only took a few hours, but it still cost me $600.
Old Dec 18, 2007 | 01:31 PM
78bigunns's Avatar
78bigunns
The BRP is a nice ride. Once my pile of a Jeep is together I plan on taking the wife from stem to stern and camping up there while we drive it.
Gotta be a blast on a bike.
Anyhow, may I dare ask what you have in your Y pipe alone?
I've been staring at headers for months, and looking at the parts catalog trying to plan out my custom Y ahead of time, while retaining the stock CAT, and using a good 3"in/3"out single muffler.
My teeth hurt from all the thinking.........just hate to get a bunch of pieces of stuff to cut/weld/fit, and not use it all up or go crazy money wise.
Old Dec 18, 2007 | 02:29 PM
Conanski's Avatar
Conanski
I got all my parts from a local hot rod shop, but the online prices will be similar. Take this link for example... http://www.mandrelbendingsolutions.c...uminized+Steel.
The J bends were $25 or so, the Y pipe was $45 or so, Had a local muffler shop punch out a set of 2.5" header couplers for $20 because I couldn't find any premade locally. This is all mild or aluminized steel, not stainless btw. I didn't need any extra tubing besides the two J bends to make the complete Y pipe assembly.
Old Dec 18, 2007 | 02:34 PM
Conanski's Avatar
Conanski
The BRP is a nice ride. Gotta be a blast on a bike.
Completely wore out a set of tires on my old Kawi ZX10!! Couldn't get the smile off my face for weeks after we got back.
Old Dec 18, 2007 | 02:58 PM
msb71's Avatar
msb71
Originally Posted by red89notch
studs wont make gasket changing easier, it makes it harder. the gaskets have holes on either side of teh header port and a "hook" on the outside 2 holes allowing you to unbolt all teh head bolts but the 2 outside ones allowing you to leave the header in place and slide the gasket out.
a stud mount system will leave the gasket in place as it has studs going thru the gaskets.
just use wd-40 the tried and trued method
Had a mechanic tell me the studs are easier for him and they are better down the road , won't sieze on ya or nothing, but I definitly see your point, had to change the gaskets on my older(78) stock manifolds, and it had the hooks on em , they were pretty easy to do.
Old Dec 19, 2007 | 07:04 AM
78bigunns's Avatar
78bigunns
Thanks for the link Paul, if I can't find something local, I want to do it like yours, cut, fit, weld it all myself.
Only diff is due to funds, I'd like to keep the stock cat, have to get creative there I guess. It has dual in's and single out.
Unless there is a cheaper cat somewhere, looking online they get expensive quick.
Old Dec 19, 2007 | 08:08 AM
Conanski's Avatar
Conanski
No you don't want the stock cats. The Magnaflow 3" universal cat I bought was only $85-100.
Old Dec 19, 2007 | 09:48 AM
95F350XL's Avatar
95F350XL
Ebay Has cheap nice cats. I put a set on my friends 98 cobra so he could go through inspection. Was like 60 shipped. Here is the link for the 3" one.http://cgi.ebay.com/ebaymotors/3-Cat...QQcmdZViewItem
Old Dec 19, 2007 | 10:45 AM
78bigunns's Avatar
78bigunns
I'll have to look up the Magnaflow one. Was looking at their mufflers already.
Thanks for the link Chris, but it says the weight on that one is 6k.
I have the same truck as you and it weighs 7kish empty.
Can this work? Shouldn't a cat be rated for the vehicles GVW?
Thanks
Old Dec 19, 2007 | 11:06 AM
95F350XL's Avatar
95F350XL
Cat is rated for Liter of engine.
Old Dec 24, 2007 | 09:22 AM
Boz86's Avatar
Boz86
leaking headers
Put headers on my 92 F150 a couple of years ago. Never could get them to quit leaking, ending up pulling them off and having the manifold side remachined.
That fixed the problem. Hopefully you won't have the same issues, but thought I'd throw my experiences out.
Old Dec 24, 2007 | 11:43 AM
  #28
95F350XL's Avatar
95F350XL
I use Mr. Gasket Ultra Seals. They have never leaked on me. Even when a few header bolts missing. http://store.summitracing.com/partde...?part=MRG-5930
Old Dec 24, 2007 | 06:28 PM
  #29
matt12's Avatar
matt12
Just an update started the exhaust project this afternoon started removing headers and so far every stud has broken on me so i got pissed off and now the motor is going to come out so that i can get better access. dam that rust on plow trucks. I will update again when i get some progress. Matt
Old Dec 24, 2007 | 09:55 PM
  #30
95F350XL's Avatar
95F350XL
They all broke? 2 the block or just the heads? Mine didnt even look like there was any bolt. It was just 1 peice of crust. I got mine out some how. Oh yea for 1 week I sprayed every bolt 3 times a day with WD-40, PB Blaster, And Liquid Wrench.
