6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 any good??
Old Dec 29, 2007 | 04:46 AM
rallem's Avatar
rallem
Originally Posted by origcharger
Both Ford and Dodges peak h.p ratings are at close to 3,000 rpm not 2,000 rpm.
And Cummins says this about the Dodge diesel truck:
This engine is rated with 350 horsepower at just 3013 rpm. The 6.7-liter Turbo Diesel achieves a peak torque of 650 lb-ft at 1500 rpm for the automatic transmission configuration and maintains that peak torque all the way to 2800 rpm (a "best in class" capability for a heavy-duty diesel pickup) and a full 610 lb-ft peak torque for the manual transmission.
I made the changes below
Old Dec 29, 2007 | 04:57 AM
rallem's Avatar
rallem
<TABLE cellSpacing=0 cellPadding=0><TBODY><TR bgColor=#ffffff><TD></TD><TD></TD><TD></TD><TD></TD></TR><TR bgColor=#6666cc><TD width=106 bgColor=#cccccc>POWERTRAIN
</TD><TD width=199 bgColor=#999999>
5.4L 3V Triton V-8
</TD><TD width=124 bgColor=#cccccc>
6.8L Triton 3V V-10
</TD><TD width=221 bgColor=#999999>
6.4L Power Stroke Diesel V-8
</TD></TR><TR><TD width=106 bgColor=#cccccc>Engine Type
</TD><TD bgColor=#999999>
V-8, iron block, aluminum heads
</TD><TD vAlign=top bgColor=#cccccc>
V-10, iron block, aluminum heads
</TD><TD vAlign=top width=221 bgColor=#999999>
V-8, iron block and heads
</TD></TR><TR><TD width=106 bgColor=#cccccc>Bore/Stroke
3.55 x 4.16 in
</TD><TD bgColor=#cccccc>
3.55 x 4.16 in
3.86 x 4.13 in
</TD></TR><TR><TD width=106 bgColor=#cccccc>Displacement
330 cu in, 5400 cc
415 cu in, 6802 cc
390.5 cu in, 6400 c c
</TD></TR><TR><TD width=106 bgColor=#cccccc>Compression Ratio
9.8:1
9.2:1
17.2:1
</TD></TR><TR><TD vAlign=top width=106 bgColor=#cccccc>Fuel Injection
</TD><TD vAlign=top bgColor=#999999>
Sequential multi-port electronic
High-pressure common rail
</TD></TR><TR><TD width=106 bgColor=#cccccc>Valvetrain
SOHC, 3 valves per cylinder, variable cam timing
OHV, 4 valves per cylinder
</TD></TR><TR><TD width=106 bgColor=#cccccc>Power
300 hp @ 5,000 rpm
362 hp @ 4,750 rpm
350 hp @ 3,000 rpm
</TD></TR><TR><TD width=106 bgColor=#cccccc>Torque
365 lb-ft @ 3,750 rpm
457 lb-ft @ 3,250 rpm
650 lb-ft @ 2,000 rpm
</TD></TR><TR><TD width=106 bgColor=#cccccc>Oil Capacity
7 qt
7 qt
15 qt
</TD></TR><TR><TD width=106 bgColor=#cccccc>Coolant Capacity
26.4 qt
27.5 qt
17.9 qt (engine only)
</TD></TR><TR><TD vAlign=top width=106 bgColor=#cccccc>Transmission Type
6-speed manual overdrive (all)
5-speed TorqShift automatic overdrive (all)
</TD></TR><TR><TD width=106 bgColor=#cccccc>Gear Ratios
</TD></TR><TR><TD width=106 bgColor=#cccccc>I
5.79:1
3.11:1
</TD></TR><TR><TD width=106 bgColor=#cccccc>II
3.30:1
2.22:1
</TD></TR><TR><TD width=106 bgColor=#cccccc>III
2.10:1
1.55:1
</TD></TR><TR><TD width=106 bgColor=#cccccc>IV
1.30:1
1.00:1
1.00:1
0.71:1
</TD></TR><TR><TD width=106 bgColor=#cccccc>VI
0.72:1
</TD></TR><TR><TD width=106 bgColor=#cccccc>Available axle ratios
3.73:1, 4.10:1, 4.30:1 (F-250/350)
4.30:1, 4.88:1 (F-450)
</TD></TR></TBODY></TABLE>
I guess my eyes need to be rechecked, because every time I looked at this chart, I could have sworn that I saw it saying at 2000 rpm the 6.4 liter had 350 hp, but now I see that I was wrong. I cannot find the Dodge information at this time, but will look again in the near future.
Old Dec 29, 2007 | 09:41 PM
fordfish's Avatar
fordfish
Originally Posted by richfaa
The verdict is still out on mine...4800 miles and the DPF is shot.poor mpg, poor performance. To be honest if I had to do it over again I would not by one. The truck is awsome..the the 6.4L......hummmmmm.
. I have the same, how did u know DPF was shot?
Old Jan 3, 2008 | 08:00 PM
sickofmy08-6.4's Avatar
sickofmy08-6.4
Thumbs down
Originally Posted by 006f350diesel
thinking of upgrading or going back to gas. Is the new 6.4 a POS like the 6.0 is??
yes ,if not worse. likes fuel if it runs.
Old Jan 3, 2008 | 08:08 PM
sickofmy08-6.4
Thumbs down
yes, it likes fuel, if it even runs.
Old Jan 3, 2008 | 09:23 PM
lucky7's Avatar
lucky7
Obviously, you've had some problems. What kind....besides the poor gas mileage?
Old Jan 5, 2008 | 12:54 AM
Tsubakihara's Avatar
Tsubakihara
Originally Posted by powerstroke1350
Im hearing the 6.7 is the worst out of the three. and rightfully so since its a gay dodge!!!!
I don't think anybody can argue the sucess of the 5.9L, and now the 6.7. This design is tried and true, and even your most loyal International customers will aknowledge this fact. Get a clue homer.
Old Jan 5, 2008 | 01:10 AM
keyul's Avatar
keyul
The new international school buses that we got back in the summer had the new 6.4 and a lot of the particle filters on the exhaust were failing very quickly.
Old Jan 5, 2008 | 10:21 AM
Tom Hoffman's Avatar
Tom Hoffman
Probley made in mexico with the radiators! lol That people are still having trouble with
Old Jan 5, 2008 | 05:00 PM
rallem's Avatar
rallem
Lots of third party stories. All I know is my truck is doing very well except for the mileage. I am about to put it up for the winter because the cold air is starting to hurt my already poor mileage. January is a traditionally warm winter month but then February is the coldest and I would hate ot think how my diesel engine will react to temperatures around -30 to -50 degrees farenheit.
Old Jan 5, 2008 | 06:33 PM
Tom Hoffman
Put it up for the winter? That is win your truck should shine! Being one of the only who can drive down the road after a 10" snow. Pulling your snowmobiles to the cabin, going hunting in the sticks. being able to get to the back 40 to feed the cattle. Don't put it up!!!!!!!!!!
Old Jan 6, 2008 | 08:09 PM
mustange70's Avatar
mustange70
I find all the fuel mileage complaints and comparsions (to the 7.3, a motor thats been around in some form or another since the early 80's in the trucks, theres a lot of time to perfect that motor, whereas you're trying to compare a brand new motor to it, apples to oranges people). People want stupid amounts of power, a truck that can pull 20,000+lbs, an affordable price, and excellant mpg, all while been able to drive 80mph, face facts in order to tow heavy things you need a heavy truck to be able to handle the load safely, and people want the power to get that moving, well that takes a lot of fuel to do, and when trying to make a brick crap house go 80mph, well that takes fuel too, so learn to live with it, these things are going to suck diseal no matter how you put it, heck 15-18mpg is pretty good once you take ALL factors into consideration.
rant off, flame suit on.
Old Jan 7, 2008 | 07:12 AM
  #28
rmosso1's Avatar
rmosso1
mustange70:
I agree with most of what you say, but are we kidding ourselves with all this pulling power? Here is what you said:
"People want stupid amounts of power, a truck that can pull 20,000+lbs, an "
My dwl 2008, 6.4 PSD, long bed, 4x4, KR, auto is limited to 23,500 # GCWR, which I just found out is everything, truck, trailer, dog, load and me! What the hell do I need that much horsepower for. Yeah, yeah, yeah, you can get the tow boss package for a GCWR of 26,000#.
Old Jan 7, 2008 | 03:57 PM
  #29
Tom Hoffman
15 to 18 man that would be nice try 11. My 7.3 would out run my 6.4 and it got 17
In this day and age you would think that they would go forward not back on fuel milage! And when I say 11. that is a SW SC 373 2008 6.4 empty. But not to sound to negitive it sure looks and rides nice!!
dannyadames44
Mar 14, 2023 08:45 PM
davlan88
13
Sep 10, 2013 06:47 AM
6.4pstroke
13
Oct 14, 2011 08:18 PM
stebab
Dec 29, 2010 07:44 PM
