Sponsored by: Auxito
ATF fluid
Old Dec 15, 2007 | 12:42 PM
SnowHiker's Avatar
SnowHiker
Red face ATF fluid
I live here in minnesota. i should change my ATF fluid. its so cold im gonna have a mechanic do it. what is the ballpark fiqure i should expect to pay?
Old Dec 15, 2007 | 01:41 PM
galaxie641's Avatar
galaxie641
$100-$200. Not knowing what tranny you have and either you need Mercon or MerconV it could range anywhere in there. $100 is probably even low since I assume ATF prices have gone up recently, might be more like $150 base and $250 max.
Old Dec 15, 2007 | 03:01 PM
frankyford's Avatar
frankyford
How many miles are on the fluid you have in there now, how long has been since you or that you know of has it been changed. You can change the fluid but not the filter if it's never had a change, if you change the filter you could end up with a burned tranny. Make sure you question you tranny tech about and make sure you can trust him.
Old Dec 15, 2007 | 04:05 PM
Matts72's Avatar
Matts72
150-250 is the Norm, most shops use a base Dexron III fluid and add a synthetic Mercon V supplement to turn the fluid into Mercon V.
I would recommend that you take it to a tranny shop rather than a discount store like Sears or Costco...
Old Dec 15, 2007 | 04:13 PM
BLK94F150's Avatar
BLK94F150
What? I'd love to know how a new filter will burn up a transmission.
Mike
Old Dec 15, 2007 | 06:56 PM
steve(ill)'s Avatar
steve(ill)
more bad information... at a minimum, pull the pan, drain the 5 quarts of Mercon, change the filter, wipe the residue off the vavle body and the bottom of the pan, clean the magnet, then reinstall the pan and top off the oil. if your truck is 2001 or prior, you probably have a plug in the bottom of the converter to drain another 8 quarts. a full drain is o.k., but watch for the "power flush" that can break up sediment in the crevices and get into the valve body or solenoids and cause problems.
