EBPV brake Specifics
Old Dec 15, 2007 | 08:32 AM
tjbeggs's Avatar
tjbeggs
Originally Posted by IDMooseMan
TJ, what do you mean this? I've never been sure if mine is working properly.
When I step on the brake pedal to slow down, the engine RPM drops to idle almost immediately. Is that what the EBPV does? Is mine working properly?
What you describe is normal. The Torque converter unlocks when the brakes are pushed resulting in a loss of any engine braking. If you do a EBPV brake you can make it work when you push the brake but you also add a TC lock switch to it so you can use your service brakes and EBPV brake at the same time.
When I said "if he wants the EBPV to work normally" I meant working as in from the factory to close while cold at idle in conjunciton with exhuast brake functions
Old Dec 15, 2007 | 01:03 PM
IDMooseMan's Avatar
IDMooseMan
Thanks, TJ. I was beginning to think I had a problem in the making.
Old Dec 17, 2007 | 03:19 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Originally Posted by Action4478
Cuda Jim ....Junior....
Originally Posted by Neal 97 250
Ditto. Folllowing in his footsteps. Thanx
You make me feel embarrassment, no any comparation with my MASTER, CUDA_JIM. But thanks anyway.
xbox73
May 5, 2014 06:47 PM
mtnsammy
Feb 26, 2014 11:17 AM
creator
Feb 7, 2012 11:53 AM
secondarychaos
16
Apr 12, 2008 07:42 PM
bigtorque
Dec 26, 2006 02:16 AM
