Sponsored by: Real Truck
Shifting to 4WD
Old Dec 15, 2007 | 09:02 PM
RogueSpear2023's Avatar
RogueSpear2023
Originally Posted by redford
If you can drive faster that 55 why do you need 4 wheel drive?
I know some guys you 4wd when at the dragstrip for better traction, that would be the only need for going faster than 55mph, or when towing
Old Dec 15, 2007 | 09:31 PM
redford's Avatar
redford
FTE Leadership Emeritus
True, but you're not shifting into 4H half way down the strip.
Old Dec 16, 2007 | 01:12 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I was just wondering at what speed things could start getting messed up. I've gone 30 in 4wd (going down a hill on a fire road) and I didn't want to flip in and out just to go down the hill.
Old Dec 16, 2007 | 01:41 AM
RogueSpear2023
But that is what he is asking not at what speed he can go in as we have determined to be up to 55mph. But how fast he can go in 4Hi, I would say as fast as the truck can go, normally, as long as going in straight line on pavement, or if your going to make sharp turns you should be on gravel, or another slippery surface to allow the wheels to turn at different speeds.
Old Dec 16, 2007 | 05:55 AM
Nikolai's Avatar
Nikolai
I've done 70 in 4wd before...doesn't hurt a thing. You guys are paranoid. The transfer case and front end don't care what speed you are going. And yes, there is a need. When it snows a foot on the highway and your doing 65 mph+ 4wd helps tremendously. It's a truck, not a Prius, lol.
Old Dec 16, 2007 | 10:49 AM
redford's Avatar
redford
Oh sure, as far as speed limit while in 4 wheel drive, just go as fast as you desire.
I'm talking about a speed limit to shift into 4 wheel drive.
Old Dec 16, 2007 | 11:25 AM
texastech_diesel
Token Redneck
So if you can go 70, is the warning card FoMoCo gives you paranoid also? The one that says using 4x4 on dry pavement will bind up your driveline. Cause if you're going 70, isn't there a chance you hit some pavement where all four wheels are gripping equally like on dry pavement?
Old Dec 16, 2007 | 05:34 PM
RogueSpear2023
It only hurts you to drive on dry pavement in 4wd if you are turning, as long as you going in a straight line like on a highway, or interstate, your fine. It's turning that causes the wheels to turn at different speeds (i.e. outside tire moves farther and faster than inside tire) causing the driveline to bind up, or a tire will break loose and hop. Also turning to full lock in 4 wheel drive on dry pavement is bad. But as long as your going in a realitivily straight line, and not makeing shrap turns there isn't any problems. FoMoCo, puts that stuff out becasue the feel people are to dumb to put it back in 2hi to go around corners on dry pavement, which some people are. Ford is just trying to protect the idiots, basically like all the laws we have now do, with common sense you shouldn't break the law or destroy your truck.
Old Dec 17, 2007 | 08:32 AM
bfloyd4445's Avatar
bfloyd4445
Is 55 mph the fastest you can drive in 4x4? Not that I'm looking to actually see how fast I can go in 4Hi, just curious.
I used my ESOF a dozen times yesterday and the day before, about half with the hubs lock and half in auto. Never had a single problem with front locking in at all. And Wow I can feel the front tires grip when I flip the switch. In my Ranger the back tires would just stop spinning out when I put it in 4 and I could actually move on snow, but in this truck dang theres a real difference with those front tires digging in.
I can't remember when I have used the lock position, always just use auto. The lock position is nice if something were to go wrong but in almost 20 years of ESOF use I have never had a malfunction.
pcurtice
13
Mar 16, 2024 11:48 PM
campbellsny
Mar 13, 2017 05:35 PM
jssblues
1978 - 1996 Big Bronco
Feb 4, 2012 08:59 PM
driptorch970
2009 - 2014 F150
Dec 21, 2010 11:39 AM
Bob_VT
May 20, 2002 07:45 PM
