Sponsored by: Real Truck
DRW Marker Lights Loose
Old Dec 13, 2007 | 08:23 PM
DonVito's Avatar
DonVito
Hey all you DRW owners, you might want to check your marker lights on your rear fenders if they are loose ( the yellow and red ones ) I already replaced the driver side red light and now I just noticed the passenger side red light is loose and popping out. I called my service tech today to tell him the other side is loose. He said it is a known problem and they have extra lights on hand just for this problem. My truck is a Job #1 truck. I don't know if has been addressed in the Job #2 trucks. Just FYI
Old Dec 13, 2007 | 09:06 PM
PowerStrokeHD's Avatar
PowerStrokeHD
The dealer is correct and it is a known problem...
Loose side marker lamps, 2008 dual rear wheel pickups:
Some trucks may have marker lamps that are loose on the fenders, or fall out. If the side marker lamp assembly must be replaced, discard the bulb that comes with the assembly and install bulb p/n C2AZ-13466-C. The lamp retaining bracket, F81Z-15A436-AA, should be replaced as well. Red marker lamp: F81Z-15442-BA; amber marker lamp: F81Z-15442-CA. Broadcast Message 0352.
Old Dec 15, 2007 | 10:44 AM
OTP's Avatar
OTP
I was not happy when it was dangling last month, and when I touched the Red one, it fell out in my hand. Looks like somebody put the clip on backwards. After carefully getting under the plastic well flashing, they went back in fine and no further problems.
hath
Nov 1, 2015 12:08 PM
kengarchow
Jan 16, 2015 10:48 PM
RedTaurus94
Nov 4, 2014 05:42 PM
redfire42
18
May 29, 2009 03:46 PM
