air
Old Dec 13, 2007 | 06:29 PM
MY 390's Avatar
MY 390
Talking air
Hey everybody, love this FE web!!. I am excited now!. I have a fresh 390 RV cam, dual exhaust. So i just received my new edelbrock rpm intake, a street avenger 670 cfm carb, and some hooker headers. All new!! WOW i can't weight to get it on to see how much difference it will make. I am looking at a new air cleaner ***. from k&n, it's the one that has a filter for a top and sides, can't remember what it is called, but its about $150.00 for the whole assembly. What do you experienced FE builders think about this kind of set up verses the standard air filter assembly??. I mean as far as more h.p. or whatever?. Ah the 390 is in a f250 pickup if that matters. Thank you for you inputs.
Old Dec 13, 2007 | 07:30 PM
Dave Severson's Avatar
Dave Severson
Unless you plan on running at WOT and in excess of 6500, I doubt the $150 air cleaner will make a bit more power then the $29.95 standard aftermarket chrome one. Probably some increase in power, but I'm sure you'd have to have it on a dyno to see it.....
Old Dec 13, 2007 | 08:36 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well I disagree with dave......more cam, Intake, Headers, Open filter..More air in more air out..More HP out..That simple.....Engines are nothing more than an air pump! The more the breath the better off they are!!!
RJ
Old Dec 13, 2007 | 10:37 PM
Bear 45/70's Avatar
Bear 45/70
If nothing else it will improve his Gas mieage. I added the K&N air filter to the 1999 Ranger 4.0 Liter and picked up 2 mpg. Well worth the money.
Old Dec 14, 2007 | 05:29 AM
baddad457's Avatar
baddad457
Skip the K&N filter top. It'll add nothing. Just use a K&N filter in the air cleaner of your choice.
Old Dec 14, 2007 | 06:55 AM
Ford428CJ's Avatar
Ford428CJ
Yep! I don't see a need for the top as well. But it is your money/project and if it makes you feel good, then do it LOL. I don't think you will gain anything from using that top! JMHO
Old Dec 14, 2007 | 06:58 AM
Ford428CJ's Avatar
Ford428CJ
You can buy a Horn from K&N that goes over the choke. That will gain you some HP because it straightens out the air. Those do work!!!
Old Dec 16, 2007 | 12:00 AM
f700's Avatar
f700
air cleaner
hi all i still use my old oil bath air filter , i rebuild my 360 had a paper filter on it but it keep clogging with mud spray so i went to the back of the shed and look for the old oil bath filter and thats where it stayed works great
Old Dec 17, 2007 | 09:48 AM
pbear6969's Avatar
pbear6969
??? Horn from K&N?? What is that Ford428CJ? I have never heard of or seen one of those... Where can you get that from??
EDIT::: Are you talking about Stubstacks??? It says "Requires milled off air horn." What does that mean??
Old Dec 17, 2007 | 11:00 AM
RapidRuss's Avatar
RapidRuss
Pbear......Just buy a ram air box for it.....and run some duct work and get fresh cooler air into the carb...and then buy the K&N round air filter for it.. That way if you plan on a bigger build at a later date? you have your fresh air system allready taken care of... It all depends on where you want to end up....
I did run a few vehicles with the open top cleaner....But I also had a scoop on the hood....and they worked great.... But with that said not as good with the fresh air ram box.... JMO.. its your money...and sometimes I GO over kill...but It allways ends up being one less piece to buy....LOL...
RJ
Old Dec 17, 2007 | 12:30 PM
pbear6969's Avatar
pbear6969
RJ
They make a ram air box for it???? I have a K&N filter and top for mine now, but I am always looking for something else to make an extra HP or 2..lol Enough is never enough right!?!?!
Old Dec 17, 2007 | 12:55 PM
Ford428CJ's Avatar
Ford428CJ
Its a K&N Stubstack is what they call it! Here is a link for one~
http://www.knfilters.com/Racing/stubstacks.htm
I wouldn't wast my money on a top. The only time that I would, is for hood clearance. When you have to run smaller filter (like 3" tall or less) or a shaker set-up, other wise no gain from it. Sorry Russ, don't take it to hart. Put your money where you are going to make some gains. I think Car Crafter did an article on air filters (on tall and short filters) and you would be surprised on what you don't need to make power. But each to there own & Its your money to do with what you want.......JMHO
Old Dec 17, 2007 | 01:35 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
BTW guys Russ has a really cool design for a airbox. I don't think it has the RJS patent yet but it's a good concept idea.
I really like KN filters and have used them often. I've never tried the top filter tho. And that stubstack looks wicked cool!! That's another must have for me x 2.
Old Dec 17, 2007 | 01:43 PM
pbear6969's Avatar
pbear6969
OK here is what I don't understand... What are they talking about here..>>> "This stubstack is designed to be used with Holley 390-850cfm square bore carbs (4150/4160), <b>that have had the choke horn milled off and still use an air cleaner. </b>Eliminates the need for hand polishing and radius work. Will work with all K&N Custom Chrome Racing Air Cleaners, including Tall Velocity Stack Air Cleaners."
Old Dec 17, 2007 | 02:31 PM
Freightrain's Avatar
Freightrain
There is plenty of room, run two 3" tall filter elements(or 4" for that matter). No sense in spending that kind of money for air filter.
I've run K&N filters, but if you just get the cheaper tall element and only drive it occasionally don't worry about it.
