HOW DO I SET TIMMING
Old Apr 24, 2001 | 11:44 AM
fordsrus's Avatar
fordsrus
When I pull out the SPOUT plug is the timming supposed to be in the deep V notch or 10 degrees Before the deep V. And when you put the SPOUT back in it's supposed to be in the deep V or 10 degrees before the V.
1989 Ford F-150 Custom
300-6
Old Apr 25, 2001 | 07:20 PM
hotrodford_88's Avatar
hotrodford_88
Old Apr 27, 2001 | 12:10 AM
mudinford's Avatar
mudinford
Dont even worry about the timming after you put the spout back in. You should be able to find the specs on the emissions tag on the engine. That will tell you how many degrees BTC. Most are about 10 degreesish. Set it there and see how it does. If it is hard to start advance it some or put it at 0. other than that you shoulnt have any probs.
Dan "Mudinford" MacDonald
Rather be pushing a Ford than driving a Chevy.
Like A Rock......In Water!
Rod Beauvex
May 5, 2014 02:39 PM
Jason302
Jun 9, 2011 07:52 PM
MikeGV
May 23, 2006 05:34 PM
Boldt
19
Jan 8, 2003 11:51 AM
fordsrus
Aug 3, 2001 03:12 PM
