Sponsored by: Real Truck
ABS wires cut? WTF?
Old Dec 14, 2007 | 01:19 PM
edjunior's Avatar
edjunior
Originally Posted by cyrexpl
That's what I'm thinking is most likely. I still don't get why you would cut the wires and not just unplug them, any ideas why someone might cut them?
Coulda just been lazy. Too lazy to reach in and find where they plug in. It's a lot easier with a pair of wire cutters!
Old Dec 14, 2007 | 01:39 PM
redford's Avatar
redford
FTE Leadership Emeritus
Never underestimate the depths of stupidity.
Old Dec 14, 2007 | 01:50 PM
cyrexpl's Avatar
cyrexpl
Originally Posted by 5.4L to Freedom
This may be the appropriate forum to ask, if you have faulty ABS sensor on the front hubs of a 4x4 F250 SD, can it be changed out our do i need a whole new hub bearing assembly with the sensor in it? Advance auto and autozone claim the only way to fix it is a new hub bearing... but they are also the same people who asked me for the year, make, and model of a torque wrench.
I honestly have not repelaced an ABS sensor on a SD, however, I've done it on other cars and I can't believe Ford would be that dumb to design a non-removable ABS sensor. Hopefully someone with more experience will chime in, but I'm 98% sure that they are full of crap telling you that the whole hub has to be replaced.
Old Dec 14, 2007 | 01:51 PM
cyrexpl's Avatar
cyrexpl
So true...
Old Dec 14, 2007 | 02:28 PM
cgl's Avatar
cgl
... if you have faulty ABS sensor on the front hubs of a 4x4 F250 SD, can it be changed out our do i need a whole new hub bearing assembly with the sensor in it? ...
I've replaced a few hub assemblies and they all came with new ABS sensors already included. There was a cable attached to the assembly that could not be removed. I couldn't find a way to remove one from the old hub so it appears to be a true statement.
Old Dec 14, 2007 | 04:10 PM
cyrexpl's Avatar
cyrexpl
Wow. I must say I'm quite surprised, that doesn't seem like a terribly smart design.
Old Dec 14, 2007 | 06:52 PM
Joms's Avatar
Joms
Or the previous owner might've removed the light after cutting the wires. My 02 has three ABS sensors (which also control the speedo). One for each front wheel and one for the rear diff. Whenever I unhook any of them, I get an ABS light. There should be a connector for the front ABS, attached to the plastic wheel well, on what would be the firewall side.
My ABS light will sometimes illuminate while driving in the sand or snow. Apparently the computer gets confused when one sensor reads 20 MPH and the others don't... HA!
I had this happen to me just the other day. My sister rolled her car so we were in a field full of snow trying to get it out. After getting the car on the trailer we had a heck of a time getting back up to the high way out of the field. After we got back on the road I noticed the ABS light was on. Turned the engine off and back on and it hasn't come on since.....knock on wood...
Old Dec 14, 2007 | 07:25 PM
Monster-4's Avatar
Monster-4
I am only familiar with the 99-04 models but they have replaceable ABS sensors. It can be removed from the hub via a 10MM bolt (I think).
http://www.clubfte.com/users/racergu...of100_0025.JPG
Old Dec 14, 2007 | 08:50 PM
Hootbro's Avatar
Hootbro
Ford actually calls it a "Wheel Speed Sensor" which is easily replaced.
http://www.angelfire.com/tx/hootbro/...Sensor_4x4.pdf
Unfortunately, the wheel speed sensor gets its pulse signal off a "Wheel Speed Sensor Ring" which is pressed on the disc hub. If that is the actual problem, then that can be a pain.
http://www.angelfire.com/tx/hootbro/...ensor_Ring.pdf
http://www.angelfire.com/tx/hootbro/...on_Testing.pdf
Old Dec 16, 2007 | 02:36 AM
5.4L to Freedom's Avatar
5.4L to Freedom
[QUOTE=Hootbro]Ford actually calls it a "Wheel Speed Sensor" which is easily replaced.
http://www.angelfire.com/tx/hootbro/Wheel_Speed_Sensor_4x4.pdf
http://www.angelfire.com/tx/hootbro/Wheel_Speed_Sensor_Ring.pdf
http://www.angelfire.com/tx/hootbro/ABS_Operation_Testing.pdf[/QUOTE]
The problem originated when I follewed the above directions to remove the wheel speed sensor, I unbolted it, and then it was still seized in the hub. THe applicaton of a greater force broke it. I don't know how to get the old one out now
Shake-N-Bake
17
Jul 21, 2021 12:49 PM
lightflyer
Nov 20, 2016 09:17 AM
EricE
Sep 25, 2016 02:40 PM
joeinca
Jun 9, 2016 09:18 AM
Holehawgg
40
Jan 19, 2014 07:47 PM
