Offroad & 4x4
Crossover problems STILL!!!!! ARG!!!!
Old Dec 15, 2007 | 11:22 AM
  #31
buzzbait65's Avatar
buzzbait65
in addition.....it does look like a lift is needed in order to not contact the crossmember on compression, i know others have mentioned this too
maybe stick with passenger side steering arm with a drag link from pitman arm to it and go back with the standard tie rod locations, for now at least
Old Dec 15, 2007 | 08:07 PM
  #32
STGFordCrazy04's Avatar
STGFordCrazy04
Like Ive said I really could care less about highsteer. On a mud/hunting truck when do you ever really see the tie rod getting in the way? Ive decided to do away with the highsteer tie rod in exchange for the normal stock tie rod. Most people who know me know that Im after the least amount of lift to fit the tires on the truck. For me a 8" lift would clear 44s fine with a little more hacking at the fenders. Im not lifting the truck any more right now. In fact I dont see how it would be possible to use highsteer with even a 8" lift. Lift isnt the factor in this point. Its that GD crossmember!
Quad if you bring Fishys tube bender and your welding helmet I will put a tube chassis under this truck! Not only have I seen the light I have drank the Bud Light and anything is possible at this point!
Old Dec 15, 2007 | 08:12 PM
  #33
STGFordCrazy04
Stroke,
If I turn the pitman arm the opposite way I will only make matters worse. On a 79 250 the steering box is in front of the axle and usually the pitman arm faces the driver side front tire. In my case with crossover I am turning the pitman arm 90* from stock so that it faces the rear driver side tire.
BTW. I am working in the "most detailed MFer" of a tech article....as we speak...well maybe Ill correct some stuff tomorrow when I sober up
Old Dec 16, 2007 | 01:10 PM
  #34
quadzjr's Avatar
quadzjr
just another Rockwell looser
im on my way!!!!
Old Dec 18, 2007 | 06:08 PM
  #35
STGFordCrazy04
is it a bad thing for the drag link to be at a 1.5-2* neg angle sloaping down toward the pitman arm?
If it isnt life threatning Im going to run the truck as is for now until I get a stock 79 F150 pitman arm. If not Ill go ahead and get the correct arm which would probably put the drag link level or maybe 1-2* positive angle
Old Dec 18, 2007 | 10:13 PM
  #36
quadzjr's Avatar
quadzjr
no its not going to hurt anything....
Old Dec 19, 2007 | 06:17 AM
  #37
STGFordCrazy04
Quad,
Youre my hero! I finally get to drive this POS for the first time in like a month.
Old Dec 19, 2007 | 06:52 AM
  #38
quadzjr's Avatar
quadzjr
haha.....just dont go and break somthing now....
and get some wheelin' vids!
Old Dec 19, 2007 | 04:54 PM
  #39
STGFordCrazy04
My next project is to destroy my D60 rear. Hopefully I wont break my front in the process.
Give me some details on mudfest. I know Ive got to go to Alabama for work sometime in Feb but if its not that weekend Im thinking about coming.
Old Dec 19, 2007 | 10:13 PM
  #40
quadzjr's Avatar
quadzjr
mudfest: the craziest badest *** mud boggin party of the year....
more beer and bewbies than you could ever imagine....the MOST insane trucks.....it is by far the biggest gathering of mud trucks(many way over 1000hp) in the world without a doubt.....people come from all over....its a little crazy at times, and the 4 wheeler traffic is insane but it is the coooooolest!
feb. 8th-10th
feb. 8th is 4 wheeler only day, no trucks in the bog, but sat. and sunday is open for all........its *****ing awsome!
Old Dec 20, 2007 | 05:29 AM
  #41
STGFordCrazy04
email me a little more info. hotels or just camp out...cost....what i can/cant bring
Old Dec 20, 2007 | 06:32 AM
  #42
buzzbait65's Avatar
buzzbait65
quadzjr, where is mudfest, gainesville/ocala area or down south
Old Dec 20, 2007 | 07:01 AM
  #43
fishmanndotcom's Avatar
fishmanndotcom
wish i had seen this earlier, sorry STG! the few x-overs i have assisted with we only had one hi-steer arm on the pass side and the drag link connect that arm with the pitman arm (generally stock since the hi-steer arm raises the slope a good deal). then the stock tie rod goes on top of the stock knuckles after reaming them. thats how i am running the bronco right now actually! of course very soon i should have no tie rod or pitman arm
i have a reamer but it wasnt too bad. i bought it from bronco graveyard for something like $70. it was worth that to me b/c first time i took my pitman arm to a machine shop to have them do it i got charged $75!
-cutts-
Old Dec 20, 2007 | 09:13 AM
  #44
quadzjr's Avatar
quadzjr
okeechobee....
Old Dec 24, 2007 | 01:40 AM
  #45
Ryan50hrl's Avatar
Ryan50hrl
heres how i see it.....just use a hole saw, and cut out the bottom of your crossmember, or while we're at it, so it never becomes a problem in the end, just cut the whole crossmemeber out, your motor mounts will hold the frame together....LOL.....ok serious i think your screwed unlsess you lift it more, or go back to stock steering.....best of luck
