Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Falcons
Old Dec 13, 2007 | 09:07 PM
emgee's Avatar
emgee
WOW! That was fast. I'll pass this onto my son. Thanks Fomoko 1.
Old Dec 13, 2007 | 09:27 PM
Fomoko1's Avatar
Fomoko1
Your welcome emgee, what have you been busy at? We`re short of Manitoba members here so post often!
The Falcon looks ok from the picture, hope it works out.
If you need some one to have a look we might be able to arrange that.
Old Dec 13, 2007 | 09:50 PM
effie_man's Avatar
effie_man
ya the 221 flat head in 1932, 221.0 cubic inches, bore/stroke 3.062x3.750 bhp@rpm 65@3400, torque 139 ft/lbs@ 1500 rpm
Old Dec 13, 2007 | 09:51 PM
effie_man's Avatar
effie_man
also was a 21 stud with water pumps in the heads with full floating rod bearings and the timing gear was pressed on the camshaft
Old Dec 13, 2007 | 09:53 PM
emgee's Avatar
emgee
Just working on my '80 F100 Styleside shortbox when I can. Converting a '95 box to an '80's look with new side panels (tail lights are gonna be '95s). Got a straight '83 hood (no FORD letters), couple of '92 doors (converting to manual windows) and doing the cab corners. The 300 is newer w/new carb, newer steering box and PS pump cleaned up engine and rebuilt granny tranny tower. Doing some work in the basement (no painting allowed!) and hopefully putting most of it together starting in spring 2008.
Old Dec 13, 2007 | 09:55 PM
Snowking's Avatar
Snowking
water pumps also acts as the rad hose stud. Be eaistest to pull the motor then set your timing. Also notice the fan blade is mounted to the alter, I mean generator. But can't beat it for cool factor, 24 studs begin to look common and lame.
Jez you see why shouldn't get me going on Flatheads, should know better by now.
Old Dec 13, 2007 | 10:01 PM
effie_man's Avatar
effie_man
lol well i need a partner in crime, dont i?
Old Dec 13, 2007 | 10:05 PM
Fomoko1's Avatar
Fomoko1
Good stuff emgee, some good progress being made.
Chris, we need more FE men....I`m getting lonely here!
Old Dec 13, 2007 | 10:06 PM
effie_man's Avatar
effie_man
ya 390! WHOA!!!!!!!!!!!
Old Dec 13, 2007 | 10:07 PM
Snowking's Avatar
Snowking
I'm gonna guess you'll do all the actions of hooliganism and I'll make sarcastic remarks to the victims/police/small block modders.
Old Dec 13, 2007 | 10:08 PM
Snowking's Avatar
Snowking
uhuhuh comon I'm rebuilden a 352 thats still a FE isn't it?
Old Dec 13, 2007 | 11:00 PM
Fomoko1's Avatar
Fomoko1
Yes Ryan, now stroke and poke it!
Old Dec 13, 2007 | 11:45 PM
  #28
effie_man's Avatar
effie_man
that sounds a little dirty there fearless leader. lol
Old Dec 13, 2007 | 11:50 PM
  #29
Fomoko1's Avatar
Fomoko1
Your mind is workin over time again.
It means stroke the sucker ( more cubes).
Old Dec 13, 2007 | 11:54 PM
  #30
effie_man's Avatar
effie_man
lol i know i know
