Wheel Wells
Old Dec 13, 2007 | 07:14 AM
summitho's Avatar
summitho
Wheel Wells
Quick question for you guy's. Follow me here, for example, when you are kneeling down on the driver's side front, looking into the wheel well over the top of tire, right where the plastic wheel well comes down and just about meets the frame, behind the shock, do any of you have a long 6"x20" (approx) piece of rubber that should be held in place w/plastic darts that would be fastened to the plastic wheel well, and just hang down over the frame? Reason why I ask is because I don't have any kind of a guard there on either side of the truck. Last night I just installed my 6637 filter and took it out for a drive. My only concern was keeping water from flying up onto the filter in wet conditions. That set-up is sweet by the way. Dropped 2-lbs of boost between 75 - 80 mph and the milage went up a smidge. She definitely breathes much btter.
Old Dec 13, 2007 | 10:17 AM
84-250's Avatar
84-250
yes I do (not enough letters to post until now)
Old Dec 13, 2007 | 10:22 AM
summitho's Avatar
summitho
Wheel Wells
Looks like I'll have to hit the dealership and see if I can get some that are form fitting. Thanks 84-250
Old Dec 13, 2007 | 06:09 PM
tjbeggs's Avatar
tjbeggs
I don't have any nor have I ever seen any. I can always see the exhaust manifold on every OBS truck I have seen. Never had a problem with water or snow on my Tymar though.
Old Dec 14, 2007 | 06:44 AM
summitho's Avatar
summitho
Smile Wheel Wells
Thanks TJ. I didn't remember seeing any either.
0500757Arf
Feb 3, 2026 05:37 PM
onebighangoverguy
Sep 25, 2021 10:57 AM
bayley_dl
16
May 17, 2016 04:12 PM
sbbk2nascar
Aug 18, 2013 02:54 PM
sbrider
2009 - 2014 F150
Jun 5, 2011 09:16 PM
