Idle Surge ?????
Old Dec 12, 2007 | 05:27 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Idle Surge ?????
I Was Wondering I Have A 96 Psd And When The Motor Is Cold It Runs Great But When It Gets Warm It Has A Idle Surge. Sounds Like A Big Cam In A Car. When You Tap The Throttle It Goes Away For A Few Sec And Comes Back. I Replaced The Cps And That Didnt Help. I Changed All The Fluids And Filters And That Didnt Help Either. What Next.???????????????
Old Dec 12, 2007 | 06:14 PM
Action4478's Avatar
Action4478
Those symptoms are from an internal HP oil leak..If the oil is full , you most likely need new IPR o Rings..A scanner capable of reading live data, will tell you for sure...
Old Dec 12, 2007 | 07:02 PM
PAVEMENTMAN
Is This Hard To Fix And Were Are The O-rings Located. Will This Hurt Anything Driving It This Way.
Old Dec 12, 2007 | 07:10 PM
Action4478's Avatar
Action4478
Not hard to fix ..If it is the IPR eventually, you will get a no start..
Look here....
Old Dec 12, 2007 | 07:23 PM
PAVEMENTMAN
Do You Think That Is What It Is For Sure Or Just Guessing. Will This Bring Up A Code??? Some People Told Me It Might Be A Valve Cover Gasket Shorting Out When Hot.
Old Dec 12, 2007 | 07:34 PM
Action4478's Avatar
Action4478
If it is the IPR
Guessing....(Based on experience)
If I was there With my scanner I wouldn't be guessing...
The IPR O rings are one of the easiest & cheapest tests..
If it was the wiring ,It wouldn't go away by tapping the pedal..
Tapping the pedal raises the ICP ....
Old Dec 12, 2007 | 08:19 PM
PAVEMENTMAN
Is It An Easy And Cheap Fix.???
cajunsuperduty
Oct 28, 2011 03:31 PM
Scout
Aug 21, 2008 11:16 AM
wintremute
3.0L V6
May 16, 2006 08:44 PM
93angryranger
3.0L V6
Mar 13, 2006 09:09 PM
$snooky$
Dec 3, 2004 12:01 AM
