tank capacity?
Old Dec 12, 2007 | 12:31 PM
dcara's Avatar
dcara
tank capacity?
Does the published fuel tank capacity number include filling the neck? I believe mine is a 38gal. But even when it is towards the bottom of the "E" on the fuel gauage I can only get about 32-34 gallons in it before the pump shuts off. I believe the neck will hold about 3 gallons (from previous neck fills). So I'm thinking that published number must include filling the neck.
Old Dec 12, 2007 | 12:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The published amount does not include the neck. The gauge is not very accurate, and they calibrate it so that there is fuel left when it's reading E.
Old Dec 12, 2007 | 01:23 PM
rbaker6336's Avatar
rbaker6336
on most fuel tanks they are rated at 80% fill
Old Dec 12, 2007 | 01:25 PM
BillyBob69's Avatar
BillyBob69
Also, don't forget how much diesel foams up when filling. Have you tried letting it stop...wait about 1 minute then start again?
Old Dec 12, 2007 | 01:36 PM
Izzy351's Avatar
Izzy351
If you trickle it slowly, you'll get a whole lot more in there. I have a SB which has a tank rated at 29 gallons. I can easily get more than that in there when I fill up if I take it up to the neck. When I dropped my tank for the Hutch/Harpoon, I put in about 5 gallons out of the geri cans, then about 29 gallons at the pump (this after just about completely draining the tank). That tells me that my "29" gallon tank holds closer to 34. Yours is probably over 40...
BTW, the Harpoon mod is for being able to fill to the neck MUCH faster. The last time I did it, I filled it until it clicked off, and it took less than a minute to get it up to the neck (less than a gallon). Before the Harpoon, I'd stand there for 10 minutes trickling in 5-6 more gallons to get it full.
Old Dec 12, 2007 | 02:00 PM
dcara's Avatar
dcara
Thanks - I may end up doing that harpoon mod. I'll see if can find a link to it.
Old Dec 12, 2007 | 02:30 PM
Izzy351's Avatar
Izzy351
I suggest the Hutch while you're in there. EXCELLENT mod!! Here's a link to both:
http://guzzle.rbmicro.com/hutch.html
