coolent
Old Dec 11, 2007 | 12:55 PM
kupaa's Avatar
kupaa
coolent
I just came back from costco and they have peak antifreeze for 5.86 a/gal.can i use this in my truck?Thanks
Old Dec 11, 2007 | 01:07 PM
rbaker6336's Avatar
rbaker6336
I think the cheap stuff you can use is about twice that amount,so that is probly for gassers
Old Dec 11, 2007 | 02:06 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I went to wal-mart and bought 8 gals of FINAL CHARGE. It is the red stuff and I am good for 300,000 miles. Same thing as the rotella brand.
Old Dec 11, 2007 | 02:25 PM
kupaa's Avatar
kupaa
Thanks for the reply.How much was it for a gal. and how long is it good for.BTW i think i have the green one in my truck,thats what it looks like from the plastic filler.
Old Dec 11, 2007 | 02:51 PM
Izzy351's Avatar
Izzy351
I believe the FC is ~$10/Gallon, and it's the 50/50 premixed stuff. BUT you'd have to do a complete flush to get most of your green stuff out. They say you don't have to on their site, but I wouldn't be comfortable just dumping it in without a good flush...
NAPA has the non-premixed stuff according to FC, but I don't know what they charge for it...
Old Dec 11, 2007 | 02:52 PM
miller_feed
I don't remember how much it was. I flushed the system with water I bought at wal-mart, 20 gals@ .69 per gal. Then put in the Final Charge, it is a 50-50 blend so use it straight. FWIW I could only get 6 gals in, they say 8 gals.
I also changed to the 203* stat, and the billit housing. I went to IH and bought new bolts for the housing, they are cheap.
I also changed the hoses and belt. easyer to change all together.
Old Dec 11, 2007 | 02:58 PM
miller_feed
Here is where you can get the stat and housing. http://www.dieselsite.com/index.asp?...S&Category=203
Old Dec 11, 2007 | 02:59 PM
Izzy351's Avatar
Izzy351
That's because it's nearly (if not totally) impossible to get all the water out. That's why it's better to use the full strength stuff and pour in all 4 gallons before you top off with distilled water. BUT, where you are, it certainly doesn't get cold enough to need the bottom freeze protection that 50/50 gets you. The only thing I'd be concerned with is whether or not you have enough to protect everything from corrosion or from bearing wear. But I'm **** that way...
Old Dec 11, 2007 | 03:03 PM
miller_feed
I think it will be fine. I even drained to block on the drivers side. You are right about the freeze protection where I live. I am 11 miles from the Gulf of Mexico, and 30 miles from the Texas line. I should be good.
Old Dec 11, 2007 | 03:05 PM
rbaker6336's Avatar
rbaker6336
the napa stuff is $20 a gallon
Old Dec 11, 2007 | 03:10 PM
miller_feed
The NAPA store here had no idea what I was talking about.
Old Dec 11, 2007 | 03:16 PM
rbaker6336's Avatar
rbaker6336
that sounds like a typical napa store
I had to pick up a couple gallons last week when I done my water pump,just by luck they had it.I didn't want to drive 7 miles in afternoon traffic to get rotella
Old Dec 11, 2007 | 03:35 PM
miller_feed
The horror stories people must have with parts houses. There could be a thread about these stories that would go on forever.
Old Dec 11, 2007 | 03:53 PM
rbaker6336's Avatar
rbaker6336
the only good thing about the area I'm in now is I don't have to buy parts at chain stores,I have two stores that cater to truckers and other stores where I can buy name brand parts
I can buy oem or name brand parts for around the same price as the chain stores
