General Automotive Discussion
Key-in Ignition Noise
Old Dec 11, 2007 | 05:47 AM
diver45's Avatar
diver45
Is there any EASY way to disable the pinging alarm noise that sounds when you first put the key in the ignition?
Old Dec 14, 2007 | 09:06 PM
F350-6's Avatar
F350-6
Yes you can but you might want to move this question to your truck specific section. Here's a couple of links on how it's done on the older models. I'm guessing it will be the same with your truck.
https://www.ford-trucks.com/forums/6...ml#post5090015
https://www.ford-trucks.com/forums/3...lly-quiet.html
Good luck and be sure to carry a spare key if you don't have a door keypad.
Old Dec 16, 2007 | 08:37 PM
Beerstalker's Avatar
Beerstalker
Check out post 11 in this thread. I give the instructions along with pictures.
https://www.ford-trucks.com/forums/567156-beeper.html
BTW that thread is referred to in the Super Duty Tech Folder (the first thread in the Super Duty forum). You really should check out the tech folder as it has links to a lot of good information. Here is a link to it also.
https://www.ford-trucks.com/forums/4...lder_____.html
fordman19762003
Oct 30, 2014 08:20 AM
TheProfessorofTOOL
1997 - 2003 F150
Dec 26, 2013 04:01 PM
lwibby 95EB
Sep 28, 2010 05:53 PM
BLAZE12
Apr 4, 2010 07:51 PM
mgazak
Nov 24, 2002 02:26 AM
