panel gas tank
Old Dec 10, 2007 | 05:01 PM
DR Smith's Avatar
DR Smith
Smile panel gas tank
Got the new tank for my 54 panel today .I had it built by a guy that builds fire trucks.He used my old tank as a template and made it to fit under the frame just like original.Someone was asking about panel tanks,he said he could make some more if any body wanted them.$400. picture on my gallery.
Old Dec 10, 2007 | 05:35 PM
fst56's Avatar
fst56
how many gallons is the new tank?
Old Dec 10, 2007 | 06:01 PM
DR Smith's Avatar
DR Smith
not sure it is the same size as the original.But i have not filled it yet.
Old Dec 10, 2007 | 06:29 PM
AXracer's Avatar
AXracer
I'd like a bigger tank for mine.
Old Dec 10, 2007 | 07:01 PM
4tl8ford's Avatar
4tl8ford
There is not a lot of room for expansion, I spent more than a few hrs under mine this summer tryin' to figure out a way to fit a few more gallons in there.
Old Dec 10, 2007 | 09:45 PM
AXracer's Avatar
AXracer
Some time in it's past someone has rigged Gracie with a second tank under the rear. The tank was gone , but the second fill neck in the center of the rear pan, the fuel line and the switch valve were left in place.
Old Dec 10, 2007 | 11:26 PM
4tl8ford's Avatar
4tl8ford
I'm considering running the pipes our the wheel wells and down the sides like lake pipes,
Then I could put another tank on the Pax side.
That would total up to about 34 Gal.
I'm not sure why I want so much gas, I can only drive thru a large McDonalds Coffee anyway.
Old Dec 11, 2007 | 09:44 AM
bobj49f2's Avatar
bobj49f2
As I mentioned in a previous post, I used a take off tank from a truck that was being made into a fire truck. I figure this tank is about 50% bigger than the stock. I made new mounting brackets. The new tank hangs a little lower than the stock tank but I still have a lot of clearance.
Old Dec 28, 2007 | 11:07 PM
ckltrk's Avatar
ckltrk
That tank looks great!!! I was the guy that contacted you before about the tank, but you didn't know if he would build another. I am definitely intersted in a similiar tank. Can I get his contact info?
northerndave
Mar 9, 2015 05:23 PM
kylerubin
Feb 1, 2015 01:16 PM
john/hlptruck
17
Dec 30, 2014 12:49 PM
JD_F100
26
Aug 31, 2014 10:26 AM
tinman52
Aug 4, 2014 11:43 PM
