03 expedition 5.4l eb front diff problems
Old Dec 10, 2007 | 12:29 PM
1bigmofo's Avatar
1bigmofo
I have noticed a deep whrrr sound coming from the front end when in 2wd if I switch to 4awd the whrrr goes away but when I transfer from a4wd back to 2wd I get a really loud clunk, whats happening? should be able to switch back and forth up to 80kmph.
Old Dec 11, 2007 | 09:12 PM
jttmoguls's Avatar
jttmoguls
I had this same issue with my '03. If I'm reading my service bill right, it is TSB 03-6-4. I guess there are a set of clutch springs in the front diff that engage when the a4wd or 4wd is on. On the early '03, these springs wore out quick (i was told), causing the half-shafts to build up speed, causing them to make the "whrr" you say. Sounds odd, but basically your front end is trying to go faster than you are, causing vibration. When the 4wd is installed, it goes away cause the system is engaged.
I don't know what the cost of this is (mine was covered on a ESP), but I haven't had any issues since (put about 16,000 mi since)
Hope this helps.
Larry Wall
Nov 19, 2014 04:13 PM
pickupman2002
Sep 24, 2012 02:37 PM
Enduroman
29
Dec 20, 2011 06:09 PM
mrkevin
Dec 1, 2007 10:29 PM
bother
Aug 27, 2003 08:29 PM
