still leaking
Old Dec 10, 2007 | 10:59 AM
red rock 78's Avatar
red rock 78
still leaking
I posted back in OCT. about my problem with water/coolant leaking from my exhaust.Since then I have changed my radiator and solved one leaking problem but still have water leaking out of exhaust pipe.I checked freeze plug Its good at this point pretty sure its the head or head gasket .I took pictures but have not got them on photo bucket .Between work ,deer hunting,and a wife my truck has not run since mid summer.I also found today that a fire department I used to be on is going to auction off there cherry 1978 ford f 150 brush truck and thinking of bidding on it.
Old Dec 10, 2007 | 08:31 PM
red rock 78
Link to Pictures
Here are two pictures of the leak that I have....
http://i251.photobucket.com/albums/g...50Picture2.jpg
http://i251.photobucket.com/albums/g...50Picture1.jpg
Old Dec 14, 2007 | 04:01 PM
Jmudder79's Avatar
Jmudder79
Wow. Never seen anything like that before. It looks like it its pouring out of there. Have you tried cleaning off the head to see if there are any visible craks in it? With how fast it looks like it is coming out of there it would have to be a pretty big leak.
Old Dec 14, 2007 | 04:25 PM
etachell's Avatar
etachell
If the leak is in both cylinder banks, that is usually from some sort of water heated carb spacer or passage in the intake manifold that corroded through.
If the leak is in just one cylinder bank, the two likely scenarios are:
An intake manifold gasket leak from a coolant passage to an intake port.
A head gasket leak from a coolant passage to a combustion chanber.
A starting test would be to do a leakdown test on each cylinder in that cylinder bank with the testing cylinder at TDC on a compression stroke. If you get pressure in the cooling system, it is a head gasket or cracked head.
The head and intake gaskets and the carb opening are pretty much the only places that coolant can get into a combustion chamber without being cracked/corroded parts.
The gaskets are the places I'd start first, not may rigs have water heated carb spacers, but they are out there.
Old Dec 14, 2007 | 06:46 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
What engine do you have?
Is this leaking with the engine running or off?
How well does the engine run? I would imagine it wuld isle pretty darn rough with a coolant leak like that.
Josh
Old Dec 14, 2007 | 07:30 PM
rusty7983's Avatar
rusty7983
do yuo have coolant in the oil, or oil pan? what shape or color are the plugs? is one plug discolored but not others? if coolant is in the pan or on the plugs maybe the intake gasket is shot. coolant leaving the coolant passage and entering the combustion chamber.
Old Dec 14, 2007 | 07:31 PM
rusty7983's Avatar
rusty7983
get a radiator pressure tester, and see/ listen to where it comes from. the oil cap maybe? or on the top of the intake?
Old Dec 14, 2007 | 08:17 PM
gilllawn's Avatar
gilllawn
Take the intake off and see if you have Antifreeze in the compartment. If not, take the heads off and replace the gaskets. It's definately internal. Based on my experience it's probably the head gasket though.
If it's in the oil make sure to remove the oil pan and clean that out as well. Lifters, pushrods, bottom of intake can be cleaned with brake cleaner.
Good Luck
JG
Old Dec 14, 2007 | 08:25 PM
ANTIDodge's Avatar
ANTIDodge
im gonna say a head gasket till i looked at the pictures but that is the worst thing ive ever seen i cant belive it still runs like that
Old Dec 14, 2007 | 09:11 PM
Bullitt390's Avatar
Bullitt390
Could be a crack into the exhaust port, thereby not getting into the engine oil or combustion.
Definately pressure test and hear (see) if air escapes into the intake or crankcase.
Josh
Old Dec 18, 2007 | 11:21 AM
red rock 78
Thanks for all your feedback. To answer your question about the oil there is no water on the dipstick. I have not checked the plugs yet. The engine is a 351m and the truck has not run since mid summer.Before that the truck ran pretty strong.
Eddie C
Mar 10, 2014 11:09 AM
Black94
Jan 30, 2013 05:00 AM
Mr. Sandman
Dec 5, 2011 06:58 PM
original67
23
Feb 27, 2004 05:51 PM
1991Explorer
Jun 17, 2002 01:37 PM
