timing chain ?'s
Old Dec 9, 2007 | 04:28 PM
7salinas3's Avatar
7salinas3
timing chain ?'s
I'm changing the timing chain on a 77 460 , I have a timing chain set for a 68 429 . This should work and take me back to the pre smog era . does this sound right ?
Old Dec 9, 2007 | 04:51 PM
FORD RANGER's Avatar
FORD RANGER
7 salinas 3,
they should be the same. compare the two chain sets. i'm pretty sure that they are the same but, set your timing at 460 specs. and not the 429 specs. however they may be the same.
ford ranger
Old Dec 9, 2007 | 05:08 PM
7salinas3's Avatar
7salinas3
I'm looking for the straight up timing, the crank gear has the " o " above the key way on the new set, I did a cross referance at the auto parts store it is the same part number . I have not yet removed the timing cover on the 460 to mach the old one.
Old Dec 9, 2007 | 05:38 PM
FORD RANGER
those are your timing marks. i thought they were the same. weather it has an "o" or a dot they should be set up the same. cam down, crank up. make sure you #1 is at top dead center first. before you dive in and pull it down. meaning your cam gear the mark
should on the bottom of the cam stroke. the crank gear should on the up stroke. your mark will be on the bottom and your crank mark faceing up on top. kind of looks like this [:] weather it be zeros or dots it sets up the same. now get after it.
sorry man just trying to help.
ok!
ford ranger
Old Dec 9, 2007 | 05:40 PM
kermmydog's Avatar
kermmydog
The 429 chain will work. But I'm not sure the 429 chain set is any different today than the modern 460 chains sets. You will need to compare them. Many of us go with aftermarket chain sets with 3 keyway settings to get back to TDC. But like I said compare them.
Old Dec 9, 2007 | 06:04 PM
7salinas3's Avatar
7salinas3
looks like I have home work after work.does any body have a part number on the chain i should use
Old Dec 9, 2007 | 06:37 PM
dirtyoffroad's Avatar
dirtyoffroad
Cloyes set is C3037,can be crossed to other #s as well,I just used this set on my 79 460
Old Dec 9, 2007 | 07:04 PM
FORD RANGER
listen man,
straight up they will interchange!! its the same part number as the 460 cid motor.
use it. you already have the parts. just get the gaskets and your set! come on guys were suposed to be helpful here! go with the stock chain set and you should be fine.
set your timing marks up and put it all back together a fire it off. note look at your distributor rotor make sure its at #1 w/ #1 up tdc.
ford ranger
Old Dec 9, 2007 | 09:32 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Originally Posted by FORD RANGER
listen man,
ford ranger
Ranger is right they will interchange, but I think his question, by referring to the "pre-smog" days is will he loose the 8 degree retard that was dialed in from the factory in the early '70's? (I think it was '72?)
I'm guessing it is possible that the '68 chain doesn't have the built in cam retard, but to be sure you will need a degree wheel. I agree with others that reccomened the aftermarket chain with the multi-index bottom gear. Advancing the cam will provide more low end torque. I would also add that I wouldn't install anyones "silent chain", I'd go with the double roller, it will be the last chain you put in that motor.
One more thing, replace that pesky bypass hose with a piece of quality hose with braided steel liner. You know high$$ the stuff, Earls, Russel etc. If you have ever been wronged by that hose, you will understand and this will prevent that sucker from ever blowing again.
Old Dec 10, 2007 | 08:34 PM
FORD RANGER
thanx man,
i really didn't think about the retarded 8 degrees.
most aftermarket chains and gears don't have that.
ford ranger
Old Dec 11, 2007 | 02:00 PM
cobraguy's Avatar
cobraguy
Guys I think the timing chain set will be the same the retard came from moving the holes in the end of the cam that the gear bolts to. Go with the Cloyes double roller you won't ever have to mess with it again.
Old Dec 16, 2007 | 01:45 AM
lewislynn's Avatar
lewislynn
No, it's the crank sprocket they changed
No matter what, if you want straight-up the "o" is directly over the keyway on the crank, nothing (as far as I know) is changed on the cam sprocket....Anything else is, well, retarded.
Old Dec 16, 2007 | 10:03 AM
460me's Avatar
460me
Someone posted a pic of the two cam sprockets,you sould see that the marks where on different spots.
Old Dec 16, 2007 | 11:55 AM
lewislynn's Avatar
lewislynn
That would be a pic worth seeing. The only ones I've seen were the crank sprockets with 3 keyways.
Old Dec 16, 2007 | 12:10 PM
460me's Avatar
460me
Sorry the crank gear.The pic showed the zero mark offset of the keyway
