Sponsored by: Auxito
Confused again!
Old Dec 9, 2007 | 03:03 PM
jaandmk's Avatar
jaandmk
Talking Confused again!
My 02 f150 4.2 manual says to use mercon v in the tranny and says to use mercon in the P/S pump. It states they are not interchangable. When I had my tranny fluid changed at the dealer they sold me tranny fluid which was rated for both. Can I put the mercon v in the P/S pump?
Thanks in advance
Old Dec 9, 2007 | 04:00 PM
ernest russell's Avatar
ernest russell
mercon v is synt. mercon is not ford dealer says dont mix them
Old Dec 9, 2007 | 04:23 PM
jaandmk's Avatar
jaandmk
If they cant be mixed how do they have one bottle that says its approved for both?
Old Dec 9, 2007 | 09:33 PM
steve(ill)'s Avatar
steve(ill)
MRCON is the old spec. MERCON V is a much better synthetic blend oil. THE old spec will go away and all older trucks will "upgrade" to MERCON V, but dont put straight MERCON in a new truck--- yes you can mix, and yes you can put V in the steering.--- but dont put MERCON in the transmission of the newer trucks.
Old Dec 10, 2007 | 05:46 PM
jaandmk's Avatar
jaandmk
Thanks for the help guys...take care
