Tach wire color/Location
Old Dec 9, 2007 | 01:23 PM
Ford Fx4's Avatar
Ford Fx4
I am installing the code alarm remote starter and need to find my tach wire.
What color is it?
And were is it coming from?
Thanks for the help
2006 5.4 F150
Old Dec 9, 2007 | 02:56 PM
ReAX's Avatar
ReAX
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2006 / Remote Start
[PRINT THIS PAGE]
12volts lt. green/purple (20A) + ignition harness
Starter red/lt. blue + ignition harness
Second Starter N/A
Ignition dk. blue/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/lt. green + ignition harness
Second Accessory N/A
Keysense black/pink + ignition harness
Power Lock pink/yellow - DKP or BCM, green plug, pin 9
Notes: The BCM (Body Control Module) is on the driver side rear cabin wall.
Power Unlock pink/lt. green - DKP or BCM, green plug, pin 1
Lock Motor pink/black 5wi DKP or BCM, blue plug, pin 2
Unlock Motor red/orange 5wi DKP or BCM, blue plug, pin 5
Parking Lights+ brown + switch or BCM, blue plug, pin 6
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light black/pink + DKP, gray plug, pin 13
Door Trigger black/yel (L), black/pink (R) - DKP, gray plug, pins 22, 23
Notes: The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is black/yellow in pin 4. The RF door trigger is black/pink in pin 5. The LR door trigger is black/lt. blue in pin 12. The RR door trigger is black/white in pin 13. Use all wires and diode isolate each.
Dome Supervision black/lt. blue + DKP, gray plug, pin 6
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT red/lt. green or red ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - parking brake switch
Horn Trigger dk. blue - switch or BCM, blue plug, pin 12
Memory Seat 1 brown/lt. green - memory seat switch on seat
Memory Seat 2 black/orange - memory seat switch on seat
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556SW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. When using the 1100X, a software change to 1100FM is needed.
Smart Starter Kill Relays: Relay Type:
Starter Relay Location:
Underdash, Passenger side fusebox, #1
Part #: 6401A
warning
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Old Dec 9, 2007 | 03:01 PM
Ford Fx4's Avatar
Ford Fx4
ok... so is this saying not to hook to any of theses wires?
Old Dec 9, 2007 | 03:15 PM
Ford Fx4's Avatar
Ford Fx4
ok nvm I got it
