The 2 coil wires - color code and function?
Old Jul 20, 2001 | 08:02 AM
TallPaul's Avatar
TallPaul
Old Jul 23, 2001 | 03:09 PM
laptopgeek's Avatar
laptopgeek
1974 F100 240 cubic inch 6 banger. Howdy y'all - trying to get the 460 cranked up with a new Unilite Promaster coil. As you've figured out, having some problems with starting. The truck USED to have the 6 cylinder in him and now has the 460 with the Mallory Unilite distributor and Promaster coil (can't get spark).
Trying to figure out (forgot to write it down!!....) what wires go where on the 6 cylinder coil and what their colors were. Could you do me a favor and look on yours? On the wiring harness left IN the F100 when the 6 banger was jerked out of it, their are (three) connectors that allow for a press on connection....one was for the oil sensor (color?...), the other was for the water temp (color?...) and the remaining was the wire that went to the coil, but did it go to + or - and what color was it?
Could you please help - I'm not getting any spark to the plug wires. This conversion is just about finished...just need to get him cranked up..
The LaptopGeek -----
1974 White F100 Custom Fleetside
460 bored .040 over & C-6 automatic 2WD
Lunati cam, L&L Headers / mounts
Holley Avenger 770CFM & Edlebrock RPM
Plush black leather 40-20-40 bench seat
38 gallon JC Whitney fuel tank
Old Jul 23, 2001 | 04:28 PM
larry derouin's Avatar
larry derouin
My dad did that once (crossed the power leads on the coil) on the '62 Rambler we rebuilt when I was in school) and WOULDN'T admit they were backwards. NO SPARK! I bugged him so much he finally relented and I swapped wires and it started right up! He still won't admit he was wrong, even today(29 years later).
The wire that powers the coil goes on the + terminal. The - terminal goes to the "points"(if ya got them) or the module. As I have an '87 my wiring set-up wouldn't do you any good.
Turn on the key and back probe all three to see which one has 12V.DC to it. The powered one will go to coil. Then short each of the other two in turn and check your gauges (put someone behind wheel). Ground each of them in turn and have the person behine the wheel tell you which one goes past the high or hot mark. Attach to corresponding sensor.
Old Jul 23, 2001 | 06:49 PM
laptopgeek's Avatar
laptopgeek
Now ~that~ my dear man was USEFUL information! Thankyou; I shall print this out and tape it to my bathroom mirror!!
Now if any other gent will kindly respond with wire colors it would make my day and allow me to get to some serious S-10 stompin'....
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
