It's the box itself that is vulnerable. I wonder what I could do with a ten inch steel pipe cut the long way? Of course - an armored mailbox is kind of overkill!
I have a large steel pipe mailbox as do most of my nieghbours. After 5 years it`s time for another cost of paint (from fading).
It was ridiculous replacing it every 6 months, usually in every spring and fall.
I got tired of kids battering my mailbox, so I built one out of 1/4 steel and mounted it on a piece of solid 2" cold roll set in 3' of concrete. I have found 2 broken bats close by, but no damage to the box yet
Hey Wiz,
I noticed you had some spring perches for sale on ebay....are they old one's cut off old axel? are they new? from your 54?
I might need a set.
Ed
Hey Wiz,
I might need a set.
Ed
Those are the seats. They were an extra set that was in the donor 54 i have, It has a Dana 41.
Virtually indestructible Made from nearly 20 lbs. of plate steel. Features recessed door with heavy duty bale wire pull. Includes heavy duty steel flag. 20" long, 9 1/4" high, 7 1/4" wide. Available in Black Only.
